J boot Vacuum connections 951
Old 09-25-2016, 05:25 PM
avants2turbo
avants2turbo's Avatar
Default J boot Vacuum connections 951
can anybody tell me what the 4th connection on the J boot is on the 951
the recirc valve
the AOS pipe
the vac pipe to the WGFV
and the 4th one, its pretty small, about 8mm and the hose 999 181 152 50 connects to it, but i cant seem to see where the other end goes
the reason for asking is, the J boot is going in the bin, ive got a silicon t piece 3" from the turbo to the air filter with a 25mm t off to the recirc/dump valve, i know i need to accommodate the AOS pipe back into the inlet pipe, the vac pipe to the WGFV is being re routed to the top chamber of the dual port wastegate (i think) but i dont know what the 4th line is and what to do with it
Old 09-25-2016, 08:14 PM
NCLA951
NCLA951's Avatar
If you are using MBC and not CV for your wastegate you do not need the hose off the J Boot. The other small one runs to the Evap system near the test port.
Old 09-25-2016, 08:45 PM
avants2turbo
evap system, near the test port, where exactly is that? is that needed? or can it be deleted?
Old 09-25-2016, 11:18 PM
NCLA951
NCLA951's Avatar
If you're looking into the engine bay from the nose, it's to the right of the brake master cylinder iirc it connects to the fuel vapor diaphragm.
Old 09-27-2016, 04:22 AM
Dash01
Dash01's Avatar
Gonna throw out the old J boot? If so, and if it's in usable condition, may I have it for the price of shipping? This for a project I have in mind.
Quick Reply: J boot Vacuum connections 951
