Bogging and smoke after replacing h2o pump and seals
#91
Here are pics of where the blue cloth braided line is used in several places. The first pic is for the clutch slave. The 2nd and 3rd pic are for the line that broke. It looks like a vacuum line. There's an electrically-controlled piece that connects one vacuum line to another. What is that piece? I can't find it in the PET diagrams.
#93
That cloth-braided hose actually goes to the clutch master.
Will defer to one of the 944/1 gurus...though, if not mistaken, that could be the auxiliary air valve.
#96
Sigh. Another order from Pelican. More waiting time for parts. :-)
#99
You need the 20x5mm upper seal:
http://www.paragon-products.com/Pors...701.613.40.htm
The lower seal is 24x5mm.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
#100
BTW, the seals I already bought/have are the same size and were both too big for both the top and the bottom. The link you mentioned should fit both top and bottom, correct? I ordered two of them.
#101
The correct AOS seals arrived today. Thanks, Jason.
I can't wait to install the AOS but can't do it as we're getting dumped by rain tomorrow. We need the water so I'll forgive Mother Nature.
#103
Had some time to work on her today because it didn't rain. Installed the AOS, intake manifold, and J-tube. I hope I didn't forget any hoses or bolts under the intake manifold. Lol. Had some good light before I cleaned up so I thought I'd take a few shots of the head before I put the cam tower on.
No extra bolts or nuts lying around so I'm good so far.
#105
Now that you've mentioned it, I'll elaborate what I did on my stock throttle cam.
I simply drilled two new holes at the new location so that the arm of the throttle cam is not being used, thus, making it act just like a circular throttle cam. I also cut a small slit (using a Dremel) to allow the end of the cable to be inserted into the hole. Notice how this is the resting position and the arm of the cam is not in the way. This way, I can put it back to stock easily by removing the nut and relocating the cable and spring to use the stock holes. It's much cheaper, too. I didn't have to buy one.
