Rebuilding power steering rack on 1989 951
I'm in the midst of rebuilding my power steering rack using the Pelican Parts DIY guide to assist me. I'm up to the part where it says I'm supposed to: "Next, you want to separate the rack tube from the housing. There is a ring on the tube that you will need to use a punch and hammer and turn the ring (red arrow) until you can separate the two."
I have been working with a punch and a hammer for an hour and nothing is happening. Anyone have any ideas to help me with this??
Thanks guys.
Thanks guys.
Sure! A good penetrating oil (crud oil or equiv. - forget WD40), heat and lots of patience. Make to use an aluminum punch to prevent messing up the lock ring. It took me days but it finally gave up...
