Cam Gear Size
Cam Gear Size
I have an '86 944NA and I'm about to do some front end work on the engine. I'd like to make sure I have all the right tools before I get started though and I'm wondering if someone can tell me the size (diameter) of the cam gear so I can make sure I have the right sized gear puller.
Thanks in advance
Thanks in advance
You don't need a gear puller to remove pulleys or Sprocket's from the front of a NA 944.
While you don't need any specialized tools to work on the front of the NA 944 engine the ArnnWorx tool set is a good investment if your planning keeping your car for a long time.
http://www.arnnworx.com/catalog/inde...roducts_id=188
You also need a triple square socket for the camshaft bolt. Snap On number: FTSM10E
