Polishing the cam tower housing?
Old 09-03-2016, 10:41 PM
Jay Wellwood
Jay Wellwood's Avatar
Looks nice - great job.
Old 09-20-2016, 10:38 PM
944 Lachlan
944 Lachlan's Avatar
Originally Posted by JRP944
Glass bead works really well. I thought about buying the Harbor Freight unit but instead purchased a similar bench top unit from Eastwood. Before and after pictures below for reference.
How did you mask off the innards? I really don't want glass beads up in my cam tower.
Old 09-21-2016, 12:30 AM
neunfünfeins
neunfünfeins's Avatar
Originally Posted by 944 Lachlan
The Haynes manual...
Originally Posted by snb13
There's your problem. Lol.
This. Can't speak for the 944 manual, but Haynes manuals are notoriously awful for a lot of other vehicles, especially anything that isn't a mass-market car. Anything that looks questionable I try to confirm with a second source.
Originally Posted by curtisr
And, you'll find a nice list of torque values and the like on the first page of each (where appropriate) chapter.
Assuming they're correct. When they're not, it can be a costly assumption.
The first time I learned this, it resulted in a cracked aluminum coolant flange.
Old 09-21-2016, 12:36 AM
neunfünfeins
Right, never blast anything that you're not sure you can remove 100% of the media from, because it WILL find a way in no matter how well you think you plugged it up. For example, a master cylinder.
Any sort of milled or polished gasket surface should also be masked.
OP, looks great!
Old 09-22-2016, 07:24 PM
JRP944
JRP944's Avatar
I very carefully taped all the openings and the sealing surfaces with blue painters tape. After blasting, I removed the tape, rinsed everything thoroughly with soap and water and blew it out with compressed air.
Justin
Old 09-22-2016, 10:35 PM
tj90
tj90's Avatar
Wow - Nice work guys. Add that project to my list!
TJ
Old 09-23-2016, 12:21 AM
KVDR
KVDR's Avatar
I had decent results (baking) soda blasting my control arms clean.
Old 09-23-2016, 11:35 PM
944 Lachlan
Default Progress update
Here are the steps I took:
wire wheel as much as possible (makes it shiny)
glass bead blast the nooks and crannies (makes it white)
clean in dishwasher (makes it dark grey)
For the lettering, I then sanded starting at 80 grit and going up to 2000. Then I buffed with an angle grinder and aluminum polish. Probably could have done better but the buffing pad was getting eaten up.
so now I know I can polish, I just don't think I want to polish all the nooks and crannies to a chrome finish. Will consider options. I just did my manifold in wrinkle red, so I could match that, but that's a lot of red.
Old 09-24-2016, 04:33 AM
333pg333
333pg333's Avatar
And after some polishing and clear coat. These things can clean up really nicely!
-Justin
Nice job. Hope you don't use that oil in your car though.
Old 09-28-2016, 09:42 PM
944 Lachlan
In the end, I got lazy and painted it. Only polished the relief. Here's a picture going back in. Relief needs a final buff.
Old 09-29-2016, 05:36 PM
ddombrowski
ddombrowski's Avatar
What are those headers coated with?
Old 09-29-2016, 11:53 PM
944 Lachlan
Exhaust headers are coated in ceramic by swaintech
Quick Reply: Polishing the cam tower housing?
