No tach bounce problem.
My DME was also fine after the wetting, once it dried off.
That sounds a lot like the normal drain path. There's a little opening on the passenger side of the battery box - water drains through there and comes out where you described. But if there's a hole in the bottom of the tray then at least some water will definitely get into the passenger foot well which is where the DME is. In my case you could feel it on the carpet.
water was dripping out of the seams under the passenger side quarter panel just before the door jam
Got the 944.2 and I'm at work so I don't haven't had time to dig real deep. But a cursory check by the DME is that it feels pretty dry, (but its has been sitting all weekend) and I can't see any fraying on the sensor wires when I pull back the boot but I hadn't looked at anywhere other than the heads. So I guess I have 3 routs to go.
1) water on the DME
2) bad reference sensor harness
3) bad DME relay
For #2 does anyone know how to check that without pulling the wire out? And how difficult is that to do?
1) water on the DME
3) bad DME relay
Why do anything other than jumper the DME relay first? It is a very common problem particularly with the chunky old 944 part number DME relay. I've also read that the URO brand cheapo new one is dodgy as well but have never tried one.
1) water on the DME
3) bad DME relay
1) water on the DME
3) bad DME relay
yes.
It shows the effects of water corrosion and appears to have now made a common electrical path to at least several points.
toasted
toasted
and you may also wish to find new 'certified Porsche' mechanics.
Yes, join your local PCA region, find the guys who own and/or race 944s and the ones who have owned their cars the longest and get referrals, as many of the Porsche wrenches currently repairing @ the stealership have no training, knowledge, or even maybe ever seen a 944 before.
Think this is bad ? Try getting help from one on a 914 or 356 ........
wouldn't waste my time. See where the corrosion has gone under the sealed surface meant to keep an electrical path from shorting ? Its unreliable at best and may certainly fritz out something else. Get a new one and make sure the water leak that ruined it is repaired as well.
Agreed. An easy way to tell if it's dead is to check the boot gauge with the ignition on and motor not running. If the relay isn't supplying power to the DME/KLR, the boost gauge will sit dead. If the relay is working, the gauge will read "1". I think of it as a two part test -- is boost gauge at 1, and do you get tach bounce? The combo of those two go a long way toward diagnosing a problem. I actually though the "certified" mechanic tested that, but re-reading the first post doesn't actually mention it, so it makes you wonder where that certificate came from. Hard to say from a picture whether it works, but if it's original to the car I'd replace it even if it isn't the problem (and/or carry a spare).
I totally forgot to mention, the car is running. I was driving it into the parking garage at my work after picking it up from the mechanic and it died on me. I pushed it into a parking spot, pulled the relay out and put it back in and it started. I just scraped off all of the rust at my desk and I'm going to go try it again.
