coil cover removal
Old 07-16-2016, 01:30 PM
DSMblue
DSMblue's Avatar
Default coil cover removal
How to do this?
Old 07-16-2016, 04:26 PM
jhowell371
jhowell371's Avatar
IIRC there is a hex headed screw holding it closed. After you remove the screw carefully spread open the cover and slide it off.
Old 07-18-2016, 11:27 PM
DSMblue
DSMblue's Avatar
Solved - just had to insert screwdriver and twist to pop connector open. I just wanted to be sure before potentially breaking the cover. Perhaps -1 cars use the hex screw?
Old 07-19-2016, 01:52 AM
nihil
nihil's Avatar
My `87 has no hex screw, just needed some coercion. Was a pain in the *** though.
Installing a MAF by chance?
Old 07-20-2016, 05:59 PM
jhowell371
jhowell371's Avatar
No screw, I screwed up. I was thinking of the coil mount
Quick Reply: coil cover removal
