Cruise control fix.....on going
Old 07-04-2016, 08:18 PM
No Lag
No Lag's Avatar
Default Cruise control fix.....on going
Well I tried to clean the actuator and I have tried to clean up broken solder joints and still nothing. No nothing! I think I'll order some capacitors for the control unit next. Ideas?
Picture is before the cleaning.
Old 07-04-2016, 08:46 PM
KVDR
KVDR's Avatar
Subscribed.
I feel like the cruise control is the absolute very last thing I will ever fix on my car.
At that point I will have achieved perfection and the car will magically ascend to the heavens.
Old 07-04-2016, 09:59 PM
No Lag
No Lag's Avatar
I would have thought there were some common fixes!
Old 07-04-2016, 10:01 PM
KVDR
KVDR's Avatar
I think there's lots of info out there -
It's be the last thing I fix because there's always something else that needs attention.
Old 07-05-2016, 12:19 PM
sweetskillsrk
sweetskillsrk's Avatar
I just cleaned mine up real nice and put some new lithium grease in there and she started working....but only intermittently. Hopefully you'll have better luck.
Old 07-05-2016, 02:37 PM
jhowell371
jhowell371's Avatar
Mine works too well. All it wants to do is accelerate, to what speed I don't know but at 80 it's still going up. It will disengage with a pull of the stalk but pulling down doesn't seem to want cancel the previous setting. I'm thinking I need to clean the contacts in the switch. Hopefully I can get contact cleaner in there without pulling the steering wheel. Pulling the airbag always makes me a little nervous.
Old 07-05-2016, 02:54 PM
pdxfj
pdxfj's Avatar
Jhowell..
Mine does the same. I've cleaned the servo motor and checked the module under the dash. No change. My control switches are also new, so I don't think cleaning the contacts will make any difference. The CC stalk is only a momentary switch and as long as the stalk returns to center, it is not sticking.
I've done quite a bit of reading and it seems you need to change two caps on the module board since electrolytic caps dry out after so many years.
Figured I would wait until after summer to take the module out again, strip the coating on the board, re-solder the board and replace the caps.
Old 07-05-2016, 03:08 PM
No Lag
No Lag's Avatar
The fix continued today. New capacitors......and no change. Completely not responsive! What next? Stalk switch?
Getting ready to go with cup of tea.
New caps are much smaller
Old 07-05-2016, 09:58 PM
plumbum
plumbum's Avatar
Mine had bad cracks in the solder causing it not to work...in a rush I re soldered the board but then when I set the cruise it only accelerated...doh!
Picked up a used unit from wailtail and it works perfect!
Old 07-07-2016, 04:32 PM
951Tom
951Tom's Avatar
If you get a used computer, look for one off a 968 with a later date code. I think they improved as time went on.
Old 07-07-2016, 05:16 PM
No Lag
No Lag's Avatar
Good tip. Fully compatible I assume.
Old 07-07-2016, 10:29 PM
plumbum
plumbum's Avatar
only the early 944 moduals are different from what I was told
Old 07-08-2016, 11:54 AM
951Tom
951Tom's Avatar
NoLag, yes same part # according to PET for both the late 944 & 968 computer & actuator motor.
Old 07-08-2016, 01:12 PM
SloMo228
SloMo228's Avatar
My CC actually worked properly but I removed it in the name of adding lightness. I never used it much anyway, it was kind of annoying to me without a "coast/decel" function.
Old 07-08-2016, 11:27 PM
Giantviper
Giantviper's Avatar
Originally Posted by pdxfj
Jhowell..
Mine does the same as well.it continuously accelerates. I thought it was the ghost of Mr. Porsche saying drive my car like it was designed 😉. Do you know where I can get the caps or what the part number at an electronics store would be? Also where on the board are these caps you speak of?
Quick Reply: Cruise control fix.....on going
