Audi Blue, Toyota Red, Mercedes, Prestone Orange Ahhhhh!
Old 10-18-2003, 11:56 PM
cpt_koolbeenz
cpt_koolbeenz's Avatar
Default Audi Blue, Toyota Red, Mercedes, Prestone Orange Ahhhhh!
Im ready to flush and refill the coolant sytem and just picked up some Prestone extended life (silver bottle, orange liquid) from the store (along with some Prestone flush and kit). Then, just to get some good tips, I come to RL and have a look at some coolant posts. WOW! Nobody likes anything!! The least bashed coolant was the Audi Blue I think... Will I have any problems with using Prestone Extended Life? Respected company, used in millions of new cars. I heard that DEX-Cool gels up sometimes - is this true with this type of Prestone? I also heard that DEX-Cool coats everything, making our coolant passages samller, but isn't that what it is ment to protect against?
Just to finish up a little description from Prestione:
Prestone® Extended Life 5/150 Antifreeze/Coolant is recommended and formulated for use in all GM vehicles that require a GM DEX-COOL® approved formula coolant, as well as all other cars and light-duty trucks with aluminum radiators. This patented formula has a concentrated blend of premium, long-lasting inhibitors for extended performance, protecting against temperature extremes and the ravages of rust and corrosion for 5 years or 150,000 miles.
Old 10-19-2003, 12:18 AM
Randy_J
Randy_J's Avatar
Audi Blue in the 968 Cab from the dealer & Prestone in the TurboS - both with a 1/2 bottle of Redline Water Wetter to boot. They all work fine.
Old 10-19-2003, 12:39 AM
xsboost90
xsboost90's Avatar
i a likes that green stuff..yup.
Old 10-19-2003, 05:54 AM
cpt_koolbeenz
Im not seeing a problem with the stuff I bought either
But I KNOW you others have more info on the matter...
Old 10-19-2003, 06:03 AM
led
led's Avatar
As long as it's phosphate free I don't mind the color although blue looks nice
Old 10-19-2003, 06:22 AM
cpt_koolbeenz
Q: Does Prestone® Antifreeze/Coolant contain phosphates?
A: Some European automobile manufacturers request that a phosphate-free antifreeze be used in their vehicles. This issue is related to the extremely high mineral content of the water in Europe. If you were to mix an antifreeze that contained phosphates with the type of water they have in Europe, it may produce deposits that can settle in the cooling system and promote corrosion. However, in North America we do not have this type of water problem. Typical North American coolants have contained phosphates (which is part of the corrosion inhibitor package) for many years. Therefore, the question of phosphates is a non-issue here in North America. Prestone® Antifreeze/Coolant is completely safe for use in both foreign and domestic vehicles. For those consumers who would feel more comfortable using a phosphate-free antifreeze, our Prestone® Extended Life 5/150 Antifreeze/Coolant is phosphate, silicate, and borate free. This coolant uses a special chemistry and technology that extends the life of the corrosion inhibitor package so that it lasts for five years or 150,000 miles (whichever comes first), and is safe for all cars and light trucks (old or new). Prestone® Extended Life 5/150 Antifreeze/Coolant has been approved by General Motors under their DEX-COOL® specifications and is compatible with other DEX-COOL® approved coolants.
At least it is phosphate, silicate, and borate free... Any substantial drawbacks though?
Old 10-19-2003, 08:39 AM
Flight_951
Flight_951's Avatar
The dexcool apparently does not like to mix with other types of coolant. I switched two years ago to dexcool when I was having a new radiator, expansion tank, and water pump put in at the time (unrelated). This really evacuated all the old green coolant. I just drained the coolant for the first time yesterday in fact, and noticed no problems at all. I removed the upper radiator hose and looked around for gel and abnormalities - nothing. If I were to do it over again, I'd only switch to dexcool if I could guarantee cleaning out all the old green stuff first.
Old 10-19-2003, 08:55 AM
Flight_951
Flight_951's Avatar
double
Old 10-19-2003, 09:58 AM
C5Driver951
C5Driver951's Avatar
I've used the stuff for the last three years with no problems. It seems to cool fine and doesn't leave any deposits.
I used to use the VW/AUDI blue stuff, but I can't tell any difference between it and the Prestone... other than cost. As many times as I've drained my coolant for maintenance on the alternator and other items, I'll run the less expensive alternative.
Old 10-19-2003, 10:15 AM
thedyingiraffe
thedyingiraffe's Avatar
Don't forget to use distilled water!!
Old 10-19-2003, 03:06 PM
cpt_koolbeenz
Whelp sounds good! I'll be doing it today...
Thanks guys!
Old 10-26-2003, 11:54 PM
cpt_koolbeenz
Everything seems good! I flushed it about 10 times!
The pic is of the coolant that was in my car. It had been setting for about a week without a cap on. The light green stuff is jelly-like... Not good!
Someone was talking about their coolant gelling up like that - not sure what causes it... I also had a new container of the green stuff mixed with water sitting open for the same ammount of time as the stuff pictured and it was normal.
Old 10-27-2003, 12:16 AM
GOBOGIE
Budding Photographer
GOBOGIE's Avatar
Looks like lime-green jello!
Old 10-27-2003, 12:58 AM
ERAU-944
ERAU-944's Avatar
looks like something out of ghostbusters...
-Michael-
Old 10-27-2003, 01:15 AM
cpt_koolbeenz
Lol yeah! It feels pretty weird too
Quick Reply: Audi Blue, Toyota Red, Mercedes, Prestone Orange Ahhhhh!
