Low oil pressure?
Old 05-02-2016, 10:52 AM
V2Rocket
Rainman
V2Rocket's Avatar
+1, my #1 suspect in any oil pressure thread is a faulty gauge.
I have 3 or 4 spare gauges for my 944...they all read different numbers when swapped in
Old 05-02-2016, 01:38 PM
AZ520
AZ520's Avatar
Good news! Thanks
Old 05-04-2016, 06:24 AM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by AZ520
With 0-40, the engine makes a little more power, less drag.
Not worth the accelerated wear on the cam lobes and tappets.
Old 05-04-2016, 09:28 AM
AZ520
AZ520's Avatar
OK, OK I will switch back to 20-50
Old 05-04-2016, 02:03 PM
porscharu
porscharu's Avatar
0W40 is fine as well as 15W50, 5W40, 0W50 on the synthetic side. Rotella 15W40 is another good alternative, but let's not turn this into a oil debate. Use what you are comfortable with, and please don't loose any sleep over oil weight.
Old 05-12-2016, 10:10 PM
AZ520
AZ520's Avatar
Update: Swapped in a glow shift pressure gauge and it reads 38 psi at hot idle, thanks for the help!!!
Old 05-13-2016, 11:24 AM
marc abrams
marc abrams's Avatar
Good to hear. Thanks for the follow up.
Old 05-13-2016, 12:28 PM
V2Rocket
Rainman
V2Rocket's Avatar
Quick Reply: Low oil pressure?
