WTB 924 tappets screws
Old 04-27-2016, 06:43 AM
slate blue
slate blue's Avatar
Default WTB 924 tappets screws
Hi guys,
I am converting my 928 to solid cams and I had custom solid tappets made that use the 924 screw adjuster. The main issue is that the screws from Porsche are pretty dam expensive and I need 16 of them. I did buy one new one which was the B size or size 2. Just to look at the spring heights and valve lengths that are possible as my cams have 0.550"/0.505" gross lifts. So if somebody has some or has a lead on some that would be great.
Greg
Old 04-27-2016, 08:53 AM
931guru
931guru's Avatar
Start checking the U Pull It junkyards around you. There should be plenty of those cars around.
Old 04-27-2016, 10:34 AM
slate blue
slate blue's Avatar
I'm in Australia so unfortunately those options don't exist hence my post. I just thought there may be engines that people have pulled apart and aren't going back together. it certainly happens in the 928 world
Old 04-27-2016, 11:30 AM
morghen
morghen's Avatar
ask here: http://garage.ideola.com/
Old 04-29-2016, 05:52 PM
slate blue
slate blue's Avatar
Well I have searched around and no luck, it looks like new, some people think these are nla but at the moment they are still available. I suspect while current stock last so I will pony up for them soon if nobody comes forward
Cheers
Quick Reply: WTB 924 tappets screws
