Gasket Kit for Oil Pan Gasket R/R?
Would there be a gasket kit that includes all the gaskets one would need to replace the oil pan gasket on a 951? Anyone who has a 951 and has gone through this process please reply with what all you had to replace to complete the job. Also I plan on getting my parts from AutoAtlanta unless someone knows of a better place. Any help appreciated.
mmm all you need is the oil pan gasket and a drain plug gasket. I'd go to paragon products for parts.
Edit: Oops, saw this was for a 951 and not a non turbo. Still, call Jason @ paragon, he will hook you up.
Most change the rod bearings and connecting rod nuts while the pan is off. The victor reinz gasket is oem and about 50 bucks from most suppliers.
Depending on your particular 951 plumbing, you should plan on new flange gaskets for your application.
Not an AA fan but that's your call.
