NA engine rebuild thread
#32
Dear Michael: I hope that you still have the external gripper socket for the cam tower bolts, or did that one self-destruct too? Still have mine to loan you if you strip out the hex drive. As far as the blower compression ratio's go, don't shave the head..and you might want to consider a cometic gasket to help LOWER the C/R. If you need more power with the Eaton, just screw down the pop off valve like the turbo boys do.
do you know where all that is from? Holy crap. I have been taking a ton of pics - let me know if there are any I can post that would help in any way. And of course best of luck with your build Kevin!
#33
Whhhhhaaattttt? They make such a thing for the stock DME????? What? Where? How??? Links! Info!! I seen stand along knock sensors, but nothing that works to pull timing!!! I want this!!!!
#34
#36
Mike, she's purring just fine :-)
Dood, great pics.
When you put it back together you will know every piece and what shape it's in.
The mysteries will stay on the internet and out of your engine bay :-)
Great work my friend.
Dood, great pics.
#39
Well for this engine rebuild, I'm a little stuck on the crank bolt. I have a 1/2" Ingersoll-Rand impact and borrowed a buddy's compressor that was rated at ~5 CFM at 90 psi and the bolt wouldn't budge. But the compressor was leaking at the regulator so I'm going to get my own compressor this week and have a second go. I can't really use leverage, as I would simply tip over the stand or put excessive stress on the threads at the back of the block where the stand connects (bellhousing bolts). I may just carefully drill it.
#40
Rainman
Michael,
With the pan off you can turn the engine upside down, and put a 2x4 between the crank weights and the block wall.
Then you can lever against the crank bolt. I have done it with just a foot holding the stand, or by putting the stand/engine against a wall or something.
#42
I'll give a bigger bar a shot. I put my full body weight on an 18" long bar while a buddy braced the block (I had used wood holding the crank like V2 suggested). Everything is off the block except the oil pump.
#45
Yep, 82 through early 84 motors were cross-drilled. That plus forged rods, and my familiarity/parts stash with early parts, led me to this long block.
