$43,650 for a 924 !
Some STATS:
Start weight 1260 kg / 2772 Lb's
Targeted finish weight 1040kg / 2288Lb's
Savings over OE
Fibreglass :
Sunroof 8.5kg
Bonnet 10Kg
Front Badge Panel 1.5kg
Rear Hatch & Spoiler 17kg
GTS Lights 15kg
Rear Bumper 3.75kg
Front Wings x2 10kg
Front Bumper 6kg
Lexan Side Windows 2Kg
Carbon canister 1.75kg
Mirrors 5kg
TOTAL Weight Saving 75kg
Interior
Battery 13.5kg
Rear hatch motor 2kg
Seats / Mounts 24kg
Wind up window / motor 1.5kg
Stereo / speakers 4.75kg
Sunroof motor & Cover 2.5kg
Spare wheel / jack 19.5kg
Rear seats / upholstery 11.25kg
Steering Wheel & Boss 1kg
Total 80kg
Suspension / Brakes
Calipers (x4) 13kg
Torsion Tube .5kg
Discs Front Tarox (Lighter) .5kg
Torsion bars 2kg
Rear Trailing Arms 1kg
Handbrake shoes / Cables 3kg
Total 20kg
Engine & Bay
3.0 Block 5kg
Crank 3kg
Pistons & Rods .5kg
Flywheel 4.25kg
Timing Pulley .25kg
Balance Shafts (2) 1kg
Inlet Manifold 1kg
Airbox 2.75kg
Alternator 3kg
Alternator / Bracket .5kg
Radiator .75kg
Radiator fan 1.5kg
Washer bottle 6kg
Header tank .5kg
Misc ? 4kg
Total 34kg
Exhaust
System 11.5kg
Manifold 4.5kg
Total 16kg
Grand Total 225kg
Savings over OE
Fibreglass :
Sunroof 8.5kg
Bonnet 10Kg
GTS Lights 15kg
Rear Bumper 3.75kg
Front Wings x2 10kg
Front Bumper 6kg
Mirrors 5kg
Interior
Battery 13.5kg
Seats / Mounts 24kg
Total 80kg
Suspension / Brakes
Calipers (x4) 13kg
Torsion Tube .5kg
Torsion bars 2kg
Total 20kg
Engine & Bay
3.0 Block 5kg
Crank 3kg
Pistons & Rods .5kg
Flywheel 4.25kg
Timing Pulley .25kg
Inlet Manifold 1kg
Airbox 2.75kg
Alternator 3kg
Radiator .75kg
Radiator fan 1.5kg
Washer bottle 6kg
Header tank .5kg
Misc ? 4kg
Total 34kg
Exhaust
System 11.5kg
Manifold 4.5kg
Total 16kg
Grand Total 225kg
https://rennlist.com/forums/924-931-...ight-loss.html
Well, as we all know, the coming of the New Year causes us to consider weight loss. Yes, I’m all in! Let me tell you how my track car lost 225 pounds in 30 days.
It started with a review of all the heavy items on the car that could be removed or replaced. Using my corner balance scales, here are some interesting numbers (note- # equals pounds):
Starting weight – 2501#
Front bumper – 30#
Rear bumper – 24#
Sunroof – 12#
Door – 38# (Stripped) 58# (Complete, with windows)
Hood – 42#
Rear hatch – 54#
Passenger seat – 26#
Headlight assy – 6#
I went to local metal supply house and purchased three 4′ x 8′ sheets of 1/16″ thick aluminum. About $225. A full 4×8 sheet weighs 14#. I started with the rear bumper. I started there because my metal shaping skills are only marginal and I wanted to get up to speed on an area that was not so obvious. Here is the result. 5# installed!
Read the rest of the article here:
http://newhillgarage.com/2016/02/07/...ght-loss-plan/
Front bumper – 30#
Rear bumper – 24#
Sunroof – 12#
Hood – 42#
Rear hatch – 54#
Headlight assy – 6#
Interesting comparison.
This lister shaved 225 pounds off his car (about as half as much as you claim) and had to replace doors, bumpers, hatch and sunroof with sheet aluminum yet you get to keep doors and bumpers and loose 225 kilos, not just pounds. Nice.
