Lightweight Exhaust system anyone make one for the 2.5?
Old 12-18-2015, 12:17 PM
924srr27l
924srr27l's Avatar
Default Lightweight Exhaust system anyone make one for the 2.5?
I have found a company in Finland that will make a system fromzzzzzzzzzzzzzzzzzzzzz
They can either
R
924srr27l is offline
Old 12-18-2015, 12:37 PM
SloMo228
SloMo228's Avatar
What are the boxes for? Mufflers?
I know there are a couple of manufacturers (Bursch, Dansk) that make cat-back exhausts that I'm sure are lighter than the stock cat-back. I doubt they were built with light weight in mind, but the factory exhaust is fairly heavy.
I've had the stock S cat-back on my scale and it's about 33 pounds. I haven't weighed the front half but I would estimate it's around 25-30 or so? Mine doesn't have the cat anymore, though. I think you could probably drop about 15-20 pounds off of that if you had a good lightweight system.
I am preparing to build my own exhaust from scratch in a month or two, I'll be using 2.5" stainless tube, a lightweight high-flow catalytic converter, a largish resonator + a medium-size muffler, and a MSDS 944S header. I haven't gotten the header yet but the weight of all the other components is about 20 pounds. I'm expecting the final product to come out to 30-40 pounds total. If you really didn't care about having a quietish car for street use and didn't use a cat, you could shave another 5-10 pounds off, probably.
SloMo228 is offline
Old 12-18-2015, 12:47 PM
924srr27l
924srr27l's Avatar
[QUOTE=SloMo228;12854416]What are the
System (Both pieces) under $1500!
R
Old 12-18-2015, 12:49 PM
V2Rocket
Rainman
V2Rocket's Avatar
Just as a data point...
The US-spec 944 NA exhaust from collector (2-1 y pipe after manifolds) to muffler tip, all stock but with an aftermarket CA-replacement cat is 38lbs.
V2Rocket is offline
Old 12-18-2015, 01:07 PM
924srr27l
924srr27l's Avatar
[QUOTE=V2Rocket_aka944;128544zzzzzzzzzzzzzzzzzzzzzzzzze different ?
R
Old 12-18-2015, 01:11 PM
SloMo228
SloMo228's Avatar
Thats less than I would have thought, based on my measurement of the cat-back section. Then again, the S exhaust has an additional small resonator that would add a few pounds. So mine would probably be around 40-42 for the exhaust up to the y-pipe. That sounds about right.
SloMo228 is offline
Old 12-18-2015, 01:18 PM
924srr27l
924srr27l's Avatar
[QUOTE=SloMo228;12854516]Thats less th
You only have to pick up (Or not) some of these fashionablezzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old 12-18-2015, 01:41 PM
SloMo228
SloMo228's Avatar
Originally Posted by 924srr27l
As with all changes / mods the best comparison is of course with what you've taken off and what your putting back etc...
The total weight loss for this project so far is almost 500Lbs,
Lots gone that I don;t need, and lots replaced with the same function but lighter.
It's expensive, but addictive and once your start, difficult to stop!
You only have to pick up (Or not) some of these fashionable Motorcycle Ti / carbon mufflers that are insanely light!
R
Yep, I bought a digital postal scale to take before/after weights of everything I remove or swap out. So far I'm at about 180lb lost. I'm not going for the full-blown stripped-out racecar build but I'm hoping I can remove at least 250lb. 500lb is impressive!
SloMo228 is offline
Old 12-18-2015, 02:10 PM
V2Rocket
Rainman
V2Rocket's Avatar
R
youll need to tie it down on a windy day
V2Rocket is offline
Old 12-19-2015, 05:39 AM
924srr27l
924srr27l's Avatar
[QUOTE=SloMo228;12854620]Yep, I boughzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
R
Quick Reply: Lightweight Exhaust system anyone make one for the 2.5?
