leak around oil pressure switch?
are these oil pressure switches prone to leaking? what other suspects should i rule out in that area. most of the engine itself seems dry
thinking about taking my friends advice and spraying some degreaser in those areas and hosing it off unless there is a better method.
if i pull that switch off with the oil in, would that be crazy?
this is the part i am suspecting
http://www.pelicanparts.com/catalog/...pg3.htm#item10
two functions....the 0-5 bar gauge and the low pressure light.
just don't start it with the sender out. should be a 24mm
I have had good luck with FAE sensors on the s320 but URO parts are commonly iffy.
