barn 924 "barn find"
Old 11-30-2015, 01:27 PM
FrenchToast
FrenchToast's Avatar
Originally Posted by odonnell
The only thing I can't stand about the 924 2.0l is the factory wheel choice.
You could get steel wheels too.....
Picture for ants:
Old 11-30-2015, 01:31 PM
chrenan
chrenan's Avatar
Very true! I've never seen a set in person. I almost think if you could find a set, have them widened, and lower the car a bunch it would be a cool look. The problem is they are 4 bolt so you don't get any of the easy Porsche brake upgrades.
Old 11-30-2015, 02:46 PM
J1NX3D
J1NX3D's Avatar
The fuel cap changed in '79 - '80
Old 11-30-2015, 07:39 PM
jbob
jbob's Avatar
as someone on the very verge of moving onto a relatively super beefy S2, this makes me nostaligic for the 924S i have that i will probably sell. something super retro about the 70s styling and all the marketing material for the original 2.0l 924 with shots of young swinging sporty 4-somes taking their 924 for a trip hang gliding or some such 1970s activity.
rad find man. keep posting insights.
Old 11-30-2015, 09:13 PM
Karl_W944
Karl_W944's Avatar
I've always maintained that if the 944 had the same front spoiler as the 924 or something close, it would be even better looking and it wouldn't have any of the problems the spoilers have nowadays (being literally bent out of shape and deformed).
Then again, we did get the front spoiler from the 924 Carrera GT, a compromise I suppose. I also wished the 944 had a cool "Carrera GT" version as well. The 924 truly had many more radical variants than the 944 it seems, must be a 70s thing.
It's amazing the number of 924s I see on craigslist in good shape, yet it seems it and the 928 I hardly ever see on the road. I kinda want a 924 for fun.
Old 11-30-2015, 11:35 PM
Noahs944
Noahs944's Avatar
Originally Posted by Brockoli
Nice two-tone 924!
I might have a timing belt cover. Do you need anything else? I will be headed over to my parents place where a lot of my 924 parts are and can take a look tonight.
Brock,
Pleasure to meet you. I will be needing a front cover and under tray.
I drained the oil out of my trans... it was so clean I could have drank it!
So I figure the 4 speed manual guts are fine, which means the metal dust exiting clutch scater-shield (bellhousing) must mean the clutch is destroyed.
As for what other parts I'll need, I am un sure at this time, do you have any trans/clutch stuff/torque tubes?
Cheers!
Old 12-01-2015, 12:41 AM
Noahs944
Noahs944's Avatar
Originally Posted by chrenan
Hi Noah, looking good! I'm building the 944 race car with Justin, he's been buying some parts off you lately to help our build. One of the guys on our team, Brock, should post here shortly, he owns a few 924s and might have some parts for you...
Thanks for speaking up and for your support brother. I was looking at your 944 na build.... HOLY that car you guys got is being raised up from the dead! I'm so proud of what you guys are doing. SUPERB!
Old 12-01-2015, 12:42 AM
Noahs944
Noahs944's Avatar
Originally Posted by thomasmryan
Cool. How early is the VIN?
....CIS reminds me of those Rabbit days.
Good question, the plate is stamped nov '77
Old 12-01-2015, 12:44 AM
Noahs944
Noahs944's Avatar
Picture for ants:
I love all the quirky paint themes & colours
Old 12-01-2015, 12:49 AM
odonnell
odonnell's Avatar
Noah you gotta pick up some euro 924 bumpers for it! They look so sleek, the N. America bumpers look terrible on the 924, as it already has skinny hips.
Old 12-01-2015, 01:18 AM
Noahs944
Noahs944's Avatar
GREAT NEWS TONIGHT:
Found reciepts from "GERMAN CAR SPECIALIST" in Calgary, Alberta from spring to fall 2012. This car I am told sat in a barn with a tarp on it. Then was driven for 2 years by someone and then changed hands. Was in rough shape when it was towed to the shop!
The list on the receipts:
#1 replace headlight motor with used motor.
#2 Fuel pressure testing & diag for running rough. Replaced injectors & fuel pump check valve.
#3 reinforce door card because of rattles & replace mirrors with used ones.
#4 Replace front McPherson strut inserts, boots, bumpers and steering rack boot kit.
#5 Install & balance 4 new tires
#6 Rear shock absorbers replaced
#7 4 wheel alignment
#8 fabricate fuel filter support
#9 inspect & repair for interior & exterior lights
#11 improve wiper arm speed & movement
#12 service battery connections & cables, charge and retest
#13 replace oil pressure sender, fuse panel repair
#14 diag rad fan failure & replace resister
#15 replace intake boot, air cleaner and misc intake items
#16 engine valve adjustment
#17 replace failed ign switch
#18 exhaust welding/repair
#19 check and adjust timing, aux air regulator, hoses
#20 complete vehicle detail
#21 replace 4 speed transaxle
#22 repair fuel tank leak & replace fuel pressure hose at tank
#23 replace clutch, resurface flyeel, lube pivots, and replace pilot bearing
#24 rebuilt torque tube
#25 replace rear main seal & oil pan gasket
#26 removed & inspect/re grease cv boots & cv joints in rear.
#27 polish crank, replace engine rod & main bearings while torque tube out.
#28 inspect rear brakes
#29 replace front brake hoses & service caliper sliders
#30 brake bleed, dot 4
#31 replace shifter bushings and ball cup bushings
#32 catalytic converter pounded out
#33 distributer rotor, cap, wires & plugs, distributer replaced.
... I am speechless. The invoices are in front of me. That's a lot of coin man!
Old 12-01-2015, 01:22 AM
Noahs944
Noahs944's Avatar
Temping my brother, but no. I gotta keep this car as the factory made it. Maybe no one else cares but I do.
If it has flaws, so be it.
But I certainly agree with you, the euro bumpers are so nice
Old 12-01-2015, 08:31 PM
J1NX3D
J1NX3D's Avatar
Picture for ants:
My 924 was similar green, it was a metallic and a bit more softer that this green.
Old 12-01-2015, 09:00 PM
thomasmryan
thomasmryan's Avatar
+924 to her originality less the stack of receipts)) a 100hp was glorious in the day.
see if the threaded inserts for the injectors are ok. maybe 17mm allen. at some point, the accumulator was increased from 20 to 40 cc on the vws to alleviate some hot start drama....and the WUR. fun stuff.
on my friends champagne edition we would bread tie the throttle plates together....like a ghetto response cam. sounded really cool until the tie broke. that car lived on three wheels
Old 12-01-2015, 10:35 PM
Noahs944
Noahs944's Avatar
So here is my story from the weekend. My british friend & I went for coffee & decided to go visit this "barn find" which was an 8 hour road trip (on paper).
By the time we arrived to the small town of Canmore, Alberta it was pitch black.
Based on detailed discussion, I would be able to drive this car home. I was told it was in a barn for years with a cover on it. Then at some recent point in time the car was sold to a young man who drove it for 2 years & than the gentleman I spoke with (a mechanic) did some basic electrical repairs for a no start. And also performed a thorough safety inspection. It was "good to drive and will come with safety approval".
So we made arrangement to meet at Fountain Tire.
The fellow met us at the door and the shop was ours. The car looked, well GOOD for it's age. He raised the car on the hoist & WOW. Very clean. Original paint. Minimal rust. Some dings and whatnot.
What I was looking for was an original car, as Porsche & Volkswagen designed it.
Quick Reply: barn 924 "barn find"
