Front turn signal issue
As you can see in the picture below, my passenger side turn signal/running light isn't illuminated when the headlights are on. When I signal a right turn, however, it turns on.
There's just one bulb in there, correct? The functional side looks like a single bulb with varying brightness for the indicator being turned on. Is this a relay issue? Anyone have experience tracking this down? Any other lighting related symptoms to look for which might be helpful? Thanks in advance...
Chainsaw
I don't believe it would be a dual element bulb. A dual element bulb is similar to a brake light. Low intensity then higher intensity (second element energized).
This blinker has a single brightness and then is on / off. To make sure, swap the good bulb in drivers side with bad holder on defective side.
I'll get the schematics out tomorrow if problem is not fixed.
NC
NC
I took a look at the bulb that was in there after reading Humboldtgrin's response, and it was dual element. One burned out. I had leftover replacement bulbs from O'Reilly's, but they were single element. Worked with the signal but not with the lights on. I haven't swapped the working dual element for the other, but the bulb that wasn't working had a broken filament and a smoky spot on the inside. Guess I just have to order the proper bulb.
Might want to order a second one for the other side; chances are they are the same age.
Actually, I keep toying with the idea of replacing the seals around all the lights. Maybe that's for lack of real issues to address, but most of the rubber looks to be original, or at least very old. This car's been in CA it's life, and kept garaged, so I'm willing to bet the former. But I drive it, so it's more important to me to keep it in good condition than original. My broken heater switch probably needs to get addressed first, though...
Chainsaw
Dielectric grease will not conduct electricity and has a much higher melting point.
Since dielectric grease does not conduct current it is not intended to be used on contacts. Instead it is used to keep rubber connectors pliable and to prevent corrosion on metal receptacles. Use very sparingly on small contact surfaces like automotive light bulbs.
Larger contact surfaces such as battery terminals are more suited for DG. The clamping action of tightening the wires to the battery terminals will squeeze out excess grease.
Last edited by NCporsche; 11-29-2015 at 11:11 AM. Reason: Original post had incorrect information
