"Project 944" started this week - Woo-hoo here we go!
#61
On top of everything else, how does it get clipped ONTO the head gasket??? I mean.... how does that even happen!?! I've seen a lot of crazy things, but that's right up on the top of the list!!!
That suspension is going to be wicked!
#62
I hear ya. I've seen a lot of damaged engines and found ask kinds of stuff floating around in them. But never have I seen anything quite like this.
The only thing I can possibly imagine is that they used some sort of spray adhesive and it picked up the tab. Other than that it's like the JFK assassination - a mystery not soon, if ever, to be solved.
Yeah I can't wait to get her together. Tomorrow we are putting the suspension, torque tube and transmission in. Then the weekend we're doing the rest. I will keep you posted.
Fronkenstein
Fronkenstein
#63
Well since that NA motor is trashed, would you consider selling a couple parts off of it? I'm looking for the coolant hardpipe that runs over the exhaust headers, and the water neck (that has the bleed screw in it).
#65
So we (me and an 18 year old kid I am mentoring) went up to the shop today and we got the 6 speed transaxle and torque tube place. I also installed Elephant Racing poly bronze spring plate bearings. We ran out of time but the torsion tube, coilovers and engine will be going in this weekend
#67
All in all its not a bad job although not one I would want to do without a lift at my age
Fronkenstein
#68
I always call up a buddy when I reinstall the tranny, we use 2 jacks. One to lift it up, and one near the tail housing to adjust the "pitch" as it goes up. Once the mounts are loosely bolted it's usually pretty easy to align it to the torque tube. 30 minute job if you've done it before.
#69
Fronkenstein
#70
Here's an update from fronkenstein's Garage. First a big thank you to JShep came up to the great white north for a few hours to lend a hand. It's always great to meet fellow enthusiasts. We had a slow start - work beckoned and a one hour phone call ensued. However we got under way and had a great time.
Besides cleaning parts we were able to install: the Elephant poly bronze bushings; the torsion tube; the trailing arms; rear coilovers; lower control arms with delrin bushings and rebuilt with a rennsport balljoint kit and new motor mounts.
Drilling and tapping the torsion tube for grease fittings was a real task. The tube send like it was fab'd from spring steel. But I am really excited about his snappy this car will feel with the coilovers (400/450#), delrin bushings, manual steering rack and Elephant poly bronze spring plate bushings.
I am starting out with 16" 6/8J Borbet wheels with medium soft Dunlop street / track tires. If I don't like them I will be going with my 17" 7/9J wheels and Michelin Cup 1's.
I am headed up Monday morning for another go at it. We still have balance shaft seals to do Everything else on this engine and to have been serviced less than 2K miles ago. So here's a plug for Los Angeles Auto Parts LAAP (ebay losangelesautoparts).
When I told them I needed everything to turn this NA into an 'S3' including cooling system, that is what I received for $5K shipped to my shop! And everything is top notch quality. That required little mental deliberation as to the cost versus value.
LAAP has built many 944 hybrids as well as turbo charging and super charging these conversations. And they told me to contact them with any questions. A very helpful crew.
After some back and forth with them with questions, Dave at LAAP, said an acquaintance knew the PO of the donor 968 and said the guy had recently dumped $10K into the engine (gawd I can't imagine what kind of service that is!).
Upon opening the valve cover the condition was as new. The cover gaskets are supple as was the sealant used at the cam humps. Cam chain appears new and the adjuster shoes had almost no sign of wear. All belts and rollers are new and possibly the wasserpumpkin .
The only things they did not do is front and rear main seals and balance shaft seals which I intend on doing especially since the right side balance shaft is leaking.
All in all this is a simple and fun swap. The only fab work is for installation of the oil cooler snorkel and 968 air box which requires some minor metal fab and welding. I had to ask for the air box to be included since they expected I would use a K&N filter.
I loathe K&N for street use, perhaps they are great for racing. I live close to the ocean, and travel to the mountains of NH and VT frequently which have a prodigious number of dirt roads both have lots of very fine dust . I have seen to many premature turbo failures due to K&N filters. Perhaps they are not properly maintained, however I am not risking my investment.
That's it for today.
Fronkenstein
Fronkenstein
#72
Awesome! I can't believe how easy this is going, nor how little work is involved!!!(little being a subjective term here)
Almost makes me wish..... naw, I won't say it..... but if I ever face a similar situation, this direction will take a very close looking at (if I don't supercharge).
Keep up the updates, loving it!
I'm very, very interested in the six speed conversion.
#73
So I have run into some snags. I installed early offset knuckles and trailing arms and a manual steering rack. The tie rods are quite hefty (17mm vs 15mm wrenching points) but they are also 1.5" too short. I have no idea what i am looking for as far as part numbers go. Any help would be appreciated.
I also need rotors and I keep seeing ebay auctions for 944 turbo or 951 rotors but they are specifically called out as M030, late offset or turbo s2. And then I've seen turbo rotors that have 10mm holes where the 14mm studs would normally fit thru. So at the risk of repeating myself I have an early offset 951 (not M030) suspension stuffed into an 87 NA - what size (thickness) rotors and if possible what part numbers?
Thanks,
Fronkenstein
Thanks,
Fronkenstein
#74
Here is the other half of the snag. So there is a connector on the 968 engine harness that looks like the 928 style power connector which is also in the 944 on the firewall just above the brake booster. However this group of 11 wires and said connector go inside the cabin under the dash. I cannot figure out where it goes. There is nothing like it on the 87 engine harness I pulled out other than the one that connects above the booster in the engine compartment. Does anyone here have a factory 968 manual and can share electrical schematics?
The 11 wire connector is on the 94 968 engine harness that goes into the cabin. The 3 write connector is on the 87 944 engine harness on the cabin side. I have no clue as to what to connect where without a schematic. I guess I could ring of the 968 side pretty easily. And I do have a factory manual for the 944. But any insight would be appreciated.
Fronkenstein
Fronkenstein
