steering rack option
I just had my Zims rebuilt steering rack start puking after 2 years, so I'm looking for info on people's experiences with the various steering rack rebuild options out there. Here's a roundup of the options I'm aware of, and what I know about them:
Porsche: $1721.50 - 2 year warranty
ZF: $995.89 - 2 year warranty
944Online: $449.00 - 2 year warranty
Maval: $454.75 - ?
Atlantic Enterprises: $350.00 - 2 year warranty
Zims: $289 - 1 year warranty
Autozone: $170 - lifetime warranty
Any more options I've missed? For some of these, I got the pricing info from one seller, and the warranty info from another, so I'm not 100% sure that this is accurate. But since the rebuilders are the same it probably is.
I'm leaning towards the Autozone option tbh. From everything I've read, it sounds like they're not too bad, and the lifetime warranty is beyond comparison with anything else.
Maval: $454.75 - ?
Maval: $454.75 - ?
Maval: $454.75 - ?
I've yet to try a depowered rack, but not sure if I'd like it. I do have an my old one so I might give that a try. But I don't really want the steering to be any heavier than it already is, plus I don't think it's entirely safe without modifying the valve, since it would put the load on parts that were not intended to take it.
If you are confident in your skills why not rebuild it yourself? I considered getting a rebuilt rack but mine was in good shape and it can be a dice roll on rebuilds. So I rebuilt it myself so far no leaks. It has a lot to do with how carefully you are removing the circlips from the shaft and properly installing the end seals with backing rings. As long as you orient the seals correctly it isn't a hard job. You will spend more time cleaning things.
Jorgen Automotive is known as the place to go for rebuilt racks for early Audis. They have a solid reputation, a lifetime warranty (if installed by a professional mechanic), and reasonable prices. Since our cars share many parts with Audis of the time period, I would think Jorgen may be a viable option.
http://www.jorgenauto.com/rack-pinion/porsche.html
You will need a punch set to remove the threaded ring and possibly to remove one of the backing plastic rings. You will also need various size sockets and or PVC parts as seal drivers. IIRC 24mm socket with extension and 1-1/4" coupling for the large seal at the bottom seal on the input shaft. A good moly grease (or any HD grease should suffice) on the rack. A quality set of split ring pliers. Hex key set. You will also need a way to secure the rack with a vice or otherwise to disassemble and reassemble. Nothing watching this video can't solve. Good luck.
Thanks, I didn't know that video was out there. I've heard lots of people say it's very tricky to get the rebuild right, but it doesn't look too bad, assuming there are no difficult parts in disassembly. I do have an old rack here so I could try taking that apart and see what it's like. But with all the other work I have to do, it's still tempting to just grab the Autozone one and be done with it!
Well looks like the Autozone option is out. I went in there and they said they're out of stock, and they have no idea when or if they will have them again. I tried ordering it from the website, and it stops me when I get to the checkout - not available. It looks like they don't do them anymore.
What did you end up doing? I have an autozone rack that just gave up the ghost today and they are checking with their supplier on Wednesday to see if there are any available. It is not looking good though.
Btw, a little over 4 years. Not to many miles on it though. Just for reference sake.
Just as a FYI the Autozone racks are available again. Just be sure to inspect them carefully before installing and remove the paint around the areas where the supply and return lines attach.
