Shopping for a wideband setup..
I'm running an AEM UEGO in my early 944 and it's really nice, for ~$150.
http://www.maperformance.com/aem-wid...FZCCaQod_eIAtQ
It has interchangeable faceplates (between AFR and lambda, in black and white), silver and black bezels, and a rotary switch on that back to configure it. It come with a bung and the instruction manual is pretty comprehensive, even gives you tables and graphs.
My only complaint is that my EMS software reads it a little leaner than the gauge indicates. The gauge is very accurate, but if you ever go to a standalone EMS, you may have to tune in open loop mode.
This setup isn't cheap, but comes with a Bosch Wideband UEGO sensor, weld in bung, 3hr data logging, data analysis, shows both boost and afr's in one gauge., and the failsafe feature allows you to set your lean threashold to prevent engine damage.
All in 1 pod, no need for multiple afr, boost gauges, and uses a usb cable to communicate with any laptop, no serial cable to usb cable, a modern piece of tech. for our aging cars..
I use this. I only ever used this, got no blown engine until now
http://www.ebay.de/itm/Innovate-MTX-...item1c2c31bba1
Yes they are a bit more spendy, but only by $20-$30 over the competition if you're a good shopper, and they seem to be a leader in there field..
If you have anything against this product speak now or forever hold your peace, I'm going to pull the trigger on it when my (actually selling) ebay auction ends and I get payed..
