Question about deleting balance shaft pullies
It's been a year & a half without the belt, now that I have the timing cover off I thought to myself "remove the balance shaft pulley". So I did.
But would appreciate if anyone knows I'm at risk of oil leaking without # 1,2,3,4, 5a/5b attached.
Thank you. Sorry rennlist for posting another company's picture, I just thought it was the clearest way to communicate.
http://www.944online.com/cgi-bin/ASI...41+engine-9441
Proprietoristicly Refined
Without the BB Belt, the common result is a vibration.
Since you started with 944online, this is Ian and his information:
CAUTION: Oil Pickup tube may crack!
http://www.944online.com/cgi-bin/yab...num=1294680045
J_AZ
J_AZ
Mine have been deleted since before I owned the car. The shafts are gone too which is a slightly different scenario. A little oil leaks from the upper housing, not a ton though. Certainly less than an air cooled 911...
hahaha... 944 for the win!
Thanks for the pick tube warning (I have previously accounted for that).
I guess most peaple replace the shafts with a proper kit or run 'em normally with a belt, not a in-between like I do. But hey
The proper way to do a B/S delete remove shafts, housings, seals, etc, weld over oil ports, then most importantly, have the entire rotating assembly balanced, ( this is ideal for racing applications)
Also see here
https://rennlist.com/forums/924-931-...lete-rant.html
Also see here
Thanks for the link Kev,
I found the info especially interesting for relating how a proper plugging of the B.S. oil gallery helps improve crank lubrication.
Can someone explain to me why can I not completely delete the bs housings & shafts? I no longer use power steering, so eliminating that bracket is a plus.
Less is more as far as I can tell.
Rainman
If no PS then you can remove the whole shebang. Just make sure you weld/fill all the oil holes!
You'll find the block suddenly ripe with study bolt holes to make interesting accessory brackets and things too..lol
