924 vw gti notor swap
Hello my name is chance I have two 944's an '88 that's my dd and a '87 S that's a project car. I'm selling both and trying to get into 924's because I love the room for expansion. But to get to the real question is I know that 924's and 16v gti motors have the same fi system I just need to know how to adapt the gti bell housing to the 924 Torque tube. And any other things that could help this swap
They are both Bosch CIS fuel systems... so are Volvos, BMWs, Audis, Ferraris, etc. of the time period. That doesn't necessarily mean it's a good candidate for a swap...
Typically for engine swaps you need to worry about the engine height/width/length, engine mount configuration, bell housing/clutch configuration, exhaust plumbing, intake plumbing, wiring, throttle linkage, coolant plumbing, accessory packaging, etc.
Why do you want to swap a GTI engine into the 924? the 924 engine makes more power and it is stronger in every way.
The 924 engine offers adjustable solid lifters and almost perfect square ratio (piston run vs diameter).
It also uses a crossflow head design which can be improved and together with other mods can nudge on the 944 power levels.
It also has a lot of weight you can shave off its components for performance use.
There are solutions for increasing the capacity to 2.2L or even 2.3L....i have read somewhere that 2.4L is possible too.
The 924NA engine is a very strong one, its block comes from Daimler diesel earth movers and the head is a VAG design that has been revised by Porsche. (the turbo head is redesigned by Porsche)
Basically a 150hp 924NA can be had fairly easy by increasing compression, adding some lightness to the crank, conrods and flywheel, using propper headers and tuning the cam advance.
Sure one could spend loads of money for few hp gains but the main thing is increasing the compression and taking off material off the heavy parts...and an adjustable sprocket is not that expensive.
Thanks for the input I thought more about it the reason I was wanting to do the swap is because I plan on drifting a 924 or a 944 because of the almost perfect weight distribution. Because I bought a '87 944S to drift but there to expensive if I broke something. And 924's where I live are practically free and I love the carrera gt body kits they have an I was wondering if u guys could put down some links for some 924 performance parts. Thanks
Rainman
if you trade your 944 for a 924 you'll be 50% down on power from the get-go.
not to mention there are just some parts that are totally NLA for the 924 motor.
if you get a 924 put a more serious engine in it like the modern 1.8/2.0T or the VW2.5 I-5, rather than the ancient, rare, and hard to keep going (due to parts availability) VW 2.0 from the late 15th century.
Here's some reading for you on what you want to get into:
https://rennlist.com/forums/924-931-...4-vw-swap.html
https://rennlist.com/forums/944-turb...ap-thread.html
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
not trying to be rude, but,
it's bad enough you're considering pouring money into a 924....
now you want to do what??
just because the laws of Physics don't rule something out, doesn't mean you should go ahead and do it.
you want to get this seriously hurt... for what?
what's the gain in building a car that's going to be utterly worthless?
you really want to impress yourself? put a 3.7 I-5 Hummer 3 motor w/ a turbo into like, a 968.
at least the juice will be worth the squeeze.
How would I boost it do they make any turbo kits for em I read that it's tactically the same motor in the later bed could I use a turbo kit from one of them. Or could I just take a 931 manifold and put it on a na?
A few big names:
Pelican Parts
Paragon Products
Rennbay
Lindsey Racing
Rogue Tuning
Vitesse Racing
Depends on what you're looking for. There isn't aftermarket support for these old cars like there is for newer more widely produced ones. Thankfully suspension upgrades are pretty well available for the 924/944/968 with lots of options depending on what you're looking for and how much $$$ you want to spend. Very few companies make drivetrain upgrade parts and most if not all are for the 944 turbo engine. I don't think there are any for the early 924 engine. A few big names: Pelican Parts Paragon Products Rennbay Lindsey Racing Rogue Tuning Vitesse Racing
