Vinyl Wrapping my 944
It is the color of royalty, you should do it up. It would look quite good, even with the red bunny roof.
Speaking of numberplates: does the ol' trick of poking a small pin-hole in air bubbles still work on car-wide applications, or is that probably not a good idea on a full-car wrap you're doing to protect stuff?
Today I got
My Custom Title
My Custom Title
Not necessary with 3m 1080 vinyl because of its air channel technology. If there's a bubble you literally press on it with your thumb and it disappears.
Do it!! For a racecar you could probably knock out a 95% perfect wrap job if you don't spend hours getting **** about those 2 quarter inch creases that won't work out.
No soap solution. Basically you pick a point to start, and lay down, pull up, lay down again, as you work it down perfect. I've been avoiding using heat but it is useful in certain scenarios. 1) if you stretched it out in spots with your fingers or something, heat will return it back to perfectly smooth and flat. 2) if you need to stretch it out to make a bend or something, you can heat and pull.
I quickly found out that when you stretch a metallic wrap it results in a bit of discoloration since the metallic "flake" density is less where its been stretched. This 3m product is very nice to work with and can be manuevered just enough without heat from my experience.
From your guidance!
Today I got
My Custom Title
My Custom Title
Today I got
My Custom Title
My Custom Title
Been doing some engine work this winter, if I have her running again in the next week or two I'll make more wrap progress before heading back too school but I doubt I'll finish the job until late March. Good test to see how much the stuff fades once the car is done, considering I will have new vinyl on some panels and almost year old stuff on others.
Attachment 1357766
Attachment 1357766
