944 non turbo engine replacement
Hi. Does anyone know which model year engines would be a straight swap for my 1988 944 2.5? Can I use a anything from 86-89? Thanks for any input.
Rainman
85.5-88 are directly interchangeable.
89 will swap in but is a 2.7L engine instead of 2.5, the dme should run it ok though.
82-85 engines will swap in too but you will likely need to change a water temp sensor, idle valve, and be sure to use the DME/AFM from your 88 car.
If you're in the US the '88 has higher compression pistons and makes more power than an earlier motor. I would inspect your bottom-end for wear, and if it's still good, just use the top-end from the donor.
There is also the expense of the gasket set and new hardware, etc. My head rebuild is going to end up being around $500 plus a ton of labor. If you don't even crack open the new engine, it is way less effort and expense to just swap it in.
The head work was going to be between 4 - 800 alone. So my hope is to just drop in a motor. Thanks to all for your words of wisdom. Heading to Ohio to look at a donor now. wish me luck.
