944 v8, Power Steering
Hello. I'm trying to determine what bracket people are using with their ls1 conversions. I personally have an lm7 thats been converted with the f-body components except for one piece that I realized is different, the power steering/alternator bracket. The bracket that I have places the alternator up high rather than below the power steering reservoir. I'm looking for something that does this. I did some looking and I see references to the bracket but I can't seem to locate the actual GM/Chevy part # associated with the bracket I need so that I can purchase it. So if anyone happens to have that handy, I'd appreciate it!
Use all the F body brackets. The corvette brackets won't work. Yes, that's a drivers side 914 head light motor. I use the same thing to delete the headlight bar...
The Vette brackets do fit actually but require relocating the expansion tank. A local friend of mine did the swap using a crate LS3 that had the Vette brackets. He is using a custom made expansion tank mounted to the firewall. Probably more trouble than its worth.. just get the f-body brackets
And yes i am using a 914 drivers side headlight motor to eliminate the headlight bar. See the below links for a write up on how i got it to work..
http://944hybrids.forumotion.com/t16...nversion#27402
http://944hybrids.forumotion.com/t16...nversion#28008
