Start up day after a long time
#31
I have owned two 944's that were each sitting neglected for multiple years (7 years in one case). Both of them had stuck injectors. Varnished or whatever. I disconnected the injectors, and applied 12v directly to the pins on them, short pulses of power. I could hear them make a dull thud at first, then gradually start clicking. Then I repeated with the fuel pump hot-wired to actually flow some fresh gas thru them (not much since this has the potential to put a fair amount of gas in the cylinders). It fired up right quickly after that, running a little roughly, but it cleared up in a few minutes. SeaFoam in the gas helped a lot.
#33
#34
James, this guy is great. He give a print out of before and after.
http://www.southbayfuelinjectors.com/
#35
#36
So just to get this correct, there is no need at all to remove the rubber bung to expose terminal 4?
I have no connection between terminal 4 and the main coil output terminal. If I check the main coil output terminal to either the _ or + threaded posts I have 5.2K ohms. Maybe my coil is ok.
#37
I have no connection between terminal 4 and the main coil output terminal. If I check the main coil output terminal to either the - or + threaded posts I have 5.2K ohms. Maybe my coil is ok.
Resistances are actually ok
Primary is 0.6 ohm
Secondary is5.2K ohms via the Clarks Garage procedure.
However I do not get a spark following their ignition coil test.
I have 12V on the black wire to + but no spark when grounding the - terminal to the chassis.
I still have another coil on order, so this was just to double check.
