A useful trick for servicing
Started using clips to hold the timing belt in place while servicing the top end or waterpump. Used this technique a few times because I was concerned with loosing the tooth engagement on the crank. Thought I'd share...
This is a good idea if not using a flywheel lock.
Another tip is when you have the crank at TDC lined up at the bell housing access hole, I also paint a mark on the crank pulley and oil pan to align. This way I don't have to keep looking for crank TDC via the access hole.
Dear Noah! thanks for the water pump pic! Now I am certain as to how the belt goes when it is next to the chrome belt guide on the water pump..My 83 didn't have one, but it will shortly, and this shows the proper belt routing over and under and around everything..Thanks again, Tiger 03447
I'd be careful because if the crank wants to turn, it's gonna turn, and those clips won't stop it. If you don't have a flywheel lock, at least take out the spark plugs so the crank won't turn on its own due to compression.
It's easy to check the timing (and it should be checked when you're done with the belts). Line up the TDC mark on the flywheel, and see if the TDC mark on the cam sprocket also lines up. If the belt skipped any teeth, you'll find out right away!
