Vacuum valve?
Old 03-26-2015, 08:48 PM
Noahs944
Noahs944's Avatar
Default Vacuum valve?
Anyone know what the diaphram (adjustable regulator looking thing) is...? Located just left of the booster on a 944 n/a?
-Specifically can we control vacuum on our fuel regulator with it?
Thanks!
Noah
Old 03-26-2015, 09:48 PM
V2Rocket
Rainman
V2Rocket's Avatar
left from the front of the car or from the driver seat?
left from the driver seat from the booster are the fuel vapor valves, they have nothing to do with fuel pressure.
Old 03-26-2015, 09:59 PM
odonnell
odonnell's Avatar
On all the 944s I've seen, the FPR (and damper) draw vacuum from the throttle body.
Just out of curiosity, why do you want to adjust the fuel pressure on an NA car?
Old 03-27-2015, 01:41 AM
Noahs944
Noahs944's Avatar
Yes sir from the driver's side. "control valve 1" I think it's labelled.
Old 03-27-2015, 01:44 AM
Noahs944
Noahs944's Avatar
Thank you. I need to increase the pressure (technically I want to enrich the mixture)... because when driving with sustained higher rpms I noticed the WB02 starts reading 14/1. Too lean.
Old 03-27-2015, 06:48 AM
MAGK944
MAGK944's Avatar
You need to replace your FPR with an adjustable one to do that. As Spencer said, the vacuum canister you are referring to is an emissions control valve for fuel vapor and nothing to do with fuel pressure.
Old 03-27-2015, 09:22 AM
marc abrams
marc abrams's Avatar
Yes, is part of the evap system, controls the purge of the carbon canster.
Old 03-27-2015, 11:05 AM
odonnell
odonnell's Avatar
What about adjusting the FQS switch on the dme? That should give you some control. Or what about a rising rate FPR? Im sure there's something on the market that you could make work
Old 03-27-2015, 11:22 AM
V2Rocket
Rainman
V2Rocket's Avatar
Noah,
If you get the Rogue MAF setup and DME tuner you can program the FQS values to whatever you want.
Stock is gives you +/3 or +/-6% fuel (iirc) but you can change those values however high as you need.
Old 03-27-2015, 09:01 PM
Noahs944
Noahs944's Avatar
Really? Great Geebus I wish I had a Rogue MAF kit!
Quick Reply: Vacuum valve?
