AFM tuning possible?
Thanks so much for the input! I'm seeing the same "fattening" at the same point in the RPM range. Since posting I've adjusted the FQS settings and it's is about one point better. That part I'm happy about. Good enough for me.
The power dropping off radically is apparently not merely the AFR. I believe the 4 degree cam key is too much. I don't have enough time to swap back by this weekend. I'll suffer through and short shift it.
Josh - I completely forgot about your Tuner Pro files. Awesome!
Thanks for taking your time to respond. I appreciate it. -Kerry
