Fuse Relay wiring connection needed
I'm removing 2x alarms and an immobiliser from my 1989 944S2 and there are 2x black/yellow wires from connector E on the fuse relay board I cannot trace.
Both wires have been cut very short close to the E connector block and were joined to an obsolete immobiliser with plain black wires.
Has anyone got a fuse relay board or wiring loom that they could check for me please to see where these 2x black /yellow wires should connect to the loom .
One of the yellow/black wires ( terminal E32 on the E block ) supplies a switch-live feed to terminal 86 on the DME relay (presumably from the ignition switch ?) on the schematic it says it connects to B62 ? wherever that is ?
The other wire I have no idea where it should attach.
I've intended to post this video link for some time in case it might be helpful to anyone else removing their alarm system or fitting an immobiliser .
