Spring Cleaning Good Used Parts FS:
Old 02-21-2015, 02:01 PM
boost feen
boost feen's Avatar
Default Spring Cleaning Good Used Parts FS:
Please PM me if interested in anything these are all tested good used 944/968 parts thanks
968 rear hatch complete with dark blue painted wing $850 inquire please
Tested early 944 motronic computer in stock form never opened that works well just as Bosch intended. From a clean CA car. $110 shipped conus thanks
Late HVAC controller In decent shape the defrost button sticks a bit, everything else is working normal. Has new arrow buttons, trim is cracked. $65 shipped
Good condition storage cubby from center console of 968 for all 1985/2 and later 944 968 center consoles. Good working analog clock no problems, clock can also can be removed for installing boost gauge or Air/fuel ratio gauge for that factory look. $80 shipped please PM if interested
4 point roll bar
Made by vision motorsports around 15 years ago part of a custom cage in a very nice 944 cabriolet it was welded onto plates that were welded down to floor. I have cut less than 1/2" off the bottom to remove and it would make a nice 4 point for anyone interested in tracking there S2 cab or added safety. Ready to weld in on some plates very good condition from non wrecked car. Prob fits into any 944 but cant gaurantee as it was made to fit a cab with ita soft top up or down.
Comes with just the main 4 point roll bar the front section was cut off for removal out of car. $150 + ship
Drivers side rear turbo/S2 under bumper spoiler or diffuser. Painted 1989 linen mettalic which is very close to zermatt silver. Anyway brand new paint 2 years ago however it had some funny runs in base coat under clear on top edge where you see it most so they replaced with another and it came with car. Its in great shape with all 4 mounting points in good shape. Ready to bolt on or paint and go $80 shipped Thanks Pm if interested
Grant 3 spoke leather steering wheel in 7 out of 10 shape from race car. Comes with hub for mounting in 924,944, or 968 works great for you quick wheel men. Center cap or horn button not included. You can get nice Porsche crest ones on fleabay. $85 shipped thanks PM if interested please
This is a 4 piece set of ground effects or original lower rockers for the 944 cabriolet only. The front 2 pieces are the same as all 1986 and up but the long pieces are for the cabriolets double floor skin and will prob only work on a cabriolet? All 4 pieces are crack free un broken with just normal tiny scratches and rock chips. Comes with all hardware, please PM me if interested in purchase. thanks
$135 shipped CONUS
1983-1986 early offset aluminum front A-arms
These have 1995 and 1996 date codes on them and were removed from a clean CA car
They are front A-arms for any 1983-1986 Porsche 944 and 944 turbo (951)
Ball joints are nice and tight with great boots no cracking. Castor mounts in back are in great shape no cracking or warping.
They have green factory paint dots on them which usually means they have harder and tighter rubber bushings in them per M030 spec
ALso you can upgrgade to larger turbo or m030 sway bars with these arms.
Please PM me if interested thanks
$200 shipped CONUS
Part #'s 951.341.149.01
951.341.150.01
Rebuilt Late 944 1985+ - 1991 944 digital clock , I have used a high quality LCD rebuild kit with new light bulb, lens, and contacts for a brand new 20+ year life and look.
They work great guaranteed
$115 shipped without core
$85 shipped with core received
Go from this
To this
Set of F&R turbo/S2/968 calipers
Removed from a 1987 944 turbo although one of the fronts is painted red and then black and appears to be from late S2 or 968 as it doesnt have raised lettering. The front '87 and up calipers have 2 larger pistons than '86 units. At any rate they have all been removed from a street/track Clean California car and work good have blue Ate fluid in them.
$250 shipped CONUS please PM if interested thanks
Old 04-10-2015, 03:52 AM
GJB928
GJB928's Avatar
PM Sent
Quick Reply: Spring Cleaning Good Used Parts FS:
