Garage cleanout Lloyds mats, power door lock system and various parts
Old 01-04-2015, 06:09 PM
arthropraxis
arthropraxis's Avatar
Default Garage cleanout Lloyds mats, power door lock system and various parts
All of these parts are off of an 87 944 turbo with 134K miles that the #2 cylinder seized on. The prices are OBO, shipping will be extra. If you are interested let me know and I can post or email you a picture of the item.
Alarm module $25
A/C mount $20
Alternator $25
Alternator mount $20
Alternator duct cover $10
Starter $25
Passenger side airbag only, not the cover $25
Pressure plate $25
Flywheel $25
Brake/Clutch fluid reservoir $10
Brake MC $20
Brake pads almost new, no idea what brand $10
Clutch MC with lines $10
Clutch assist spring assembly $10
Power steering fluid reservoir $10
Power steering pump $25
Power steering cooler $15
Power steering rack and tie rods $50
Accel coil $25
Front springs $10
Shifter linkage $10
New never used shifter $25
Cam sensor $15
Lifters $15
Turbo charger $50
Turbo mount $20
Coolant reservoir $25
Ring and pinion that needs the fixed 3rd gear area cleaned up $100
There are more parts if you need something let me know and I will see if I have it. Anything that does not sell I am taking to the scrapper.
Old 01-04-2015, 07:32 PM
Biscuits704
Biscuits704's Avatar
PM sent.
Old 01-04-2015, 07:37 PM
odonnell
odonnell's Avatar
Is the trans for sale?
Old 01-04-2015, 07:42 PM
arthropraxis
No, the transaxle was rebuilt. The R&P were replaced because third gear spun on the shaft. The rebuilder suggested getting it machined if it was near stock power levels but the motor is nowhere near stock power levels.
Old 01-04-2015, 08:30 PM
arthropraxis
NIB Lloyds mats not the best pics but I am sure you all know what they look like.
Someone requested the pictures.
Old 01-04-2015, 10:25 PM
arthropraxis
Motor mounts sold
Old 01-04-2015, 10:39 PM
curtisr
curtisr's Avatar
I'd like the motor mounts if they're not taken.
Old 01-04-2015, 10:58 PM
HICKS
HICKS's Avatar
Pics of beige mats?
Old 01-04-2015, 11:11 PM
arthropraxis
Originally Posted by HICKS
Pics of beige mats?
As you can see they are quite dirty. I have not even vacuumed them since taking them out in 2009. They are genuine Lloyds mats and have the tag on the back of the drivers side mat along with the clips that attach to the seat frames. If they were clean and or dyed they would be good as new, there are no holes and not much wear.
Old 01-05-2015, 01:38 AM
Dougs951S
Dougs951S's Avatar
I've never seen interior mats that color before, what interior code did those come with?
edit: nvm I see now they are not factory.
Old 01-05-2015, 08:43 AM
arthropraxis
They would have been a match to the factory beige/tan interior when they were new and the photography isn't the best.
Old 01-05-2015, 09:13 AM
HICKS
HICKS's Avatar
How are the backs of those, are they falling apart?
Old 01-05-2015, 07:29 PM
arthropraxis
Where your heel would sit on the drivers side for the gas pedal, the rubberized surface coating is worn off but not worn through. The fabric weave is intact and not noticeable unless it is felt. The rest of that mat and all the others are perfect on the back. Just the front is dirty/stained/faded.
The black set are brand new, never used. I took them out of the box to take pictures.
Old 01-10-2015, 12:12 AM
arthropraxis
Bellhousing sold
Old 01-12-2015, 01:06 PM
arthropraxis
Updated list, beige mats sold.
Quick Reply: Garage cleanout Lloyds mats, power door lock system and various parts
