DIY early dashboard restoration megathread
Old 01-19-2015, 12:19 AM
  #31
odonnell
odonnell's Avatar
The ugly part of revision II is well underway. I'm still undecided whether or not I'll go back to aerosol coating it with a uniform finish, or just buy some stretchy upholstery and try and form it over the top (will require 10x less prep). Any input is very welcome, I'm basically making this up as I go along.
Old 01-20-2015, 04:54 PM
  #32
konakat
konakat's Avatar
I've been going back and forth on this for my dash. If you want to cover it without any stitching, the vinyl will have to be VERY stretchy to make it conform to the dash/instrument binnacle transition. If you find a good material, please post exactly what you used.
Old 01-20-2015, 05:47 PM
  #33
alordofchaos
alordofchaos's Avatar
Originally Posted by V2Rocket_aka944
Years ago I took one of my dashes and filled the cracks with bondo, ... but the cracks came back fairly soon (bondo isnt strongly bonded to the foam i suppose).
that takes me back a few years
https://rennlist.com/forums/924-931-...mple-diys.html
Note, in that thread, the OP mentions applying something called MEK to make the vinyl stretchy. Looks to be some nasty stuff
http://www.lowes.com/pd_206493-34228...ductId=3024048
Old 01-20-2015, 06:33 PM
  #34
catamax944
catamax944's Avatar
I think you could use car wrap vinyl on it , you can find it in leather look now .
Just prepare the surface really good so it will stick to it and use a heat gun to form it.
It wont be easy but i think it can be done.
Just an idea......
Old 01-23-2015, 12:27 AM
  #35
joeystanker
joeystanker's Avatar
Catamax,
I was just thinking the same thing.
I just peeled/chipped the vinyl off my poor dash.
I'm ready to do some shoppin'
Old 01-23-2015, 12:49 AM
  #36
joeystanker
Look, a vinyl wrap your dashboard video.
He's wrapping the dash of a late 944.
https://www.youtube.com/watch?v=ANE0dueAXSI#t=43
I am stoked to give this a try :-)
My early 944 dash may be a little tricky but I'm game.
Old 01-23-2015, 09:49 AM
  #37
joeystanker
Also...
After seeing how the center speaker cavity is blocking air flow from the Heater...
I'm going to perform a MOD that removes the speaker cavity and gives the air flow space back to the air duct.
Old 01-25-2015, 06:23 PM
  #38
Scottmyl
Scottmyl's Avatar
Finally finishing up with this project - here are some photos with out the final defrost trim in place -
refinished top, bottom and glove-box completed
waiting for paint to dry on defrost trim
refinished top, bottom and glove-box.
rmm177 (09-16-2022)
Old 01-26-2015, 07:55 PM
  #39
pdxfj
pdxfj's Avatar
That looks fantastic! Who's kit did you use and is it leather or vinyl?
Old 01-27-2015, 12:01 AM
  #40
Scottmyl
Scottmyl's Avatar
Thanks much, The entire kit is from Classic 9 (http://www.classic9leathershop.com/) I chose vinyl to keep cost down. Cheers!
Old 01-27-2015, 11:35 AM
  #41
odonnell
odonnell's Avatar
That looks awesome!!
Originally Posted by xfghfhg
I'm curious as to how well the center speaker hole fill-in holds up. That's a big area, and with thermal expansion/contraction etc of the two materials, only time will tell!
On page 2, I had some bad results with it, and I abandoned the idea. I think someone with more experience than me could easily pull it off, though.
Originally Posted by joeystanker
Also...
Let us know how you end up doing it!
As for the dash I'm working on, fiberglass will be the next attempt. That should ensure that it will never bubble or warp again.
Old 01-27-2015, 03:08 PM
  #42
joeystanker
My DA Sander showed up at the house today:
http://www.amazon.com/gp/product/B002EQ96MG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B002EQ96MG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The plan is to sand down and apply a few more layers of foam to get things smooth and level.
I then have vinyl fabric from Jo-ann Fabrics that I will be covering with and adhering with contact cement.
I'm excited to see how it goes, pass or fail.
Old 01-27-2015, 04:28 PM
  #43
Spidey944
Spidey944's Avatar
This was my original post.... some bot copied and reposted it lol. LAME!
Old 01-27-2015, 07:28 PM
  #44
joeystanker
Update Pics
After seeing the duct work for the defroster vents, I decided to remove it and delete the speaker cavity and open up the air flow.
I cut a piece of hardboard to fit, set it in to place with a bead of black gasket goo, and set in some small screws for good measure.
I'm leaving the duct off until I am done making a mess sanding.
And then Foam-a-rama.
The DA Sander just showed up in the mail so I'll sand it down and fill in a little more with more foam.
I plan to cover with vinyl so I won't have to make it totally pit free.
I'm stoked to see how it comes out.
Old 01-27-2015, 09:52 PM
  #45
joeystanker
And I'm loving my new electric DA sander:
A few more pics from tonight...
Sanding went quite well
And another fill.
Let's see if it will need another.
Quick Reply: DIY early dashboard restoration megathread
