S2 cams into 968 head?
Old 12-19-2014, 02:40 PM
JustinL
JustinL's Avatar
Default S2 cams into 968 head?
Is there anything that needs to be done to swap s2 cams with the s2 tensioner assembly into a 968 head?
The back story is that the 968 spare head I have came with a broken cam shaft, but the rest of the head seems to be ok. I bought a complete s2 engine for a long term project and have been reading that the 968 head is much better in terms of strength.
Old 12-19-2014, 06:21 PM
Arominus
Arominus's Avatar
I would think it would work, from what i remember its the original S head thats the weak one, it was kinda fixed in the s2/968 casting. Just don't try to mix cams, the 968 ones have a different tooth count so you can't mix and match. You can with S/S2 stuff though. The S exhaust cam is more aggressive than the S2 cam.
That all said, i've never done s2 cams in a 68 head it so i would set this up and check very carefully on the engine stand if everything will work.
Old 12-19-2014, 07:38 PM
Dougs951S
Dougs951S's Avatar
Isn't the intake cam also slightly more aggressive on the 2.5 liter 16v cars?
Old 12-19-2014, 07:49 PM
Arominus
Arominus's Avatar
I don't think so, i got the info from Michael Mounts posts here and he only mentioned the S exhaust cam. If the intake was better i'm sure he would be after that too.
Old 12-19-2014, 09:01 PM
JustinL
JustinL's Avatar
My spare parts list is only S2 cams, S2 head, 968 head. Swapping cams around isn't really a factor, just whether S2 cam/tensioner assembly fits. Thanks for the tips Acromius. I might have to assemble it and see if everything lines up. I was hoping someone had done this experiment prior to me.
Old 12-02-2015, 09:22 PM
pyropete125
pyropete125's Avatar
Did you ever confirm that the s2 cams and tensioner fits in fine without any additional machining?
Pete
Old 12-02-2015, 09:59 PM
jhowell371
jhowell371's Avatar
Check this out, it's one modified to fit the S2. http://forums.pelicanparts.com/porsc...ed/index3.html
Old 12-03-2015, 12:07 PM
JustinL
JustinL's Avatar
Pete
It's been a while, but I talked to Michael Mount about it and he let me know it could be done, but it's not a direct swap. I'm pretty sure it's the tensioner that isn't compatible.
Old 12-03-2015, 12:11 PM
JustinL
JustinL's Avatar
https://rennlist.com/forums/944-turb...o-myths-9.html
Found it. The answer is in here.
Old 12-04-2015, 12:00 PM
ramius665
ramius665's Avatar
You can use a 928S4 tensioner which will bolt in directly to the 968 head without modification.
Old 12-04-2015, 12:18 PM
JustinL
JustinL's Avatar
Really!? That may change my plans somewhat. Do you have a link with some pics and/or details? What cam cover gets used?
Old 12-04-2015, 02:55 PM
ramius665
ramius665's Avatar
Short answer is no, I don't have any useful links. I've got the article on my ipad so if you send me a PM with your email I'll forward it to you. I've done a lot of research on 16V turbo motors and there's an article from 911 & Porsche World from the late 90s where David Raines explains how they deleted the variocam while retaining the 968 camshafts. In the article he specifically states they used a 928S4 camshaft tensioner because it bolts directly to the 968 head without modification. Hope this helps.
Quick Reply: S2 cams into 968 head?
