951 Led lighting project
just thought id mention the lighting project im working on.
So what I'm going to do is mount 10(in each side) 1156 Led projectors where the front turn/marker lights are. the are 1" in diameter. they are up to 9w each.... So 9x20= 180w
here are some pictures of the lights, I have found them in silver black red and blue housings.
They also make bulbs that have both orange and white in the same bulb so you can have them turn orange when you turn your signal on.
So I have designed a mount for them. I intend for them to stick out slighty so you can seen the aluminum trim on the bulbs more. I think it will give a more industrial look.
will show a 3d model of the mount in a bit.
