FS: Lots of 944 Parts
Attempted to price at 50% of used at Porsche dismantlers. All parts are used. If something is off, let me know. Shipping is extra on top of listed price. Email me at christiancook43 at yahoo dot com.
Engine
944.103.111.2R "Connecting Rods, late 968, forged w/ reinforced bearing cap (17mm)
2 good (2 questionable, no cost)" $50.00
944.105.250.07 Camshaft housing $75.00
951.106.921X Waterpump, 944 turbo $65.00
944.375.123.03 Engine carrier, L $25.00
944.375.124.02 Engine carrier, R $22.50
944.101.042.02 Gear carrier, R (balance shaft) $62.50
944.107.014.11 Oil pump $90.00
944.110.095.03 M44.08/10 Throttle housing (throttle body) $60.00
944.606.121.01 Mass air flow meter 8 valve non turbo $30.00
944.110.052.02 Intake manifold, 8 valve non turbo $35.00
944.106.125.06 Coolant expansion tank $25.00
951.106.031.50 Radiator, turbo $90.00
944.504.167.01 Protective plate, plastic engine cover, non turbo $37.50
930.606.120.00 Fuel Injectors $15.00
944.607.081.03 Cover, fuel rail $7.50
Electrical
944.603.109.00 Alternator $45.00
944.603.134.01 Alternator bracket $67.15
951.604.101.00 Starter $50.00
928.631.070.00 3rd brake light $25.00
477941379B Electric motor for pop-up headlight $37.50
944.624.021.03 Electric fan (radiator - includes shroud 944.106.141.02 ) $50.00
477.955.113.B Windscreen wiper motor $131.55
Brakes
944.351.429.00 Floating caliper, front, L $50.00
944.351.430.00 Floating caliper, front, R $50.00
944.352.429.00 Floating caliper, rear, L $50.00
944.352.430.00 Floating caliper, rear, R $50.00
944.355.011.00 Brake master cylinder $62.50
944.355.023.00 Brake booster $50.00
Transmission / Drive-train
944.116.043.06 Clutch housing / cover (check casting number) $75.00
944.421.012.02 Torque Tube $300.00
911.??? Pressure Plate, Steel - Sachs 3032 055 099 $75.00
911.??? Sachs TYP MFZ 225mm lightweight aluminum sport pressure plate - Sachs 3082 069 041 from 1970-1971 911 T/E/S. This version only weighs about 9.8 lbs. $150.00
Multiple Gearshift lever w/ ****, boot & base $75.00
944.424.019.00 Gear shift rod $25.00
922.421.051.02 Clamping sleeve, drive shaft $42.50
951.116.085.00 Clutch release lever $37.50
Multiple Early transmission suspension assembly $30.00
944.375.287.04 Transmission support (late) $17.50
Suspension, Front
944.341.103.06 Control arm cross member /LL (Engine cradle) $50.00
944.347.011.24 Steering Rack, 944, power steering $122.50
944.347.033.01 Tie-Rod, 924 / 944 early $27.54
944.347.333.01 Tie rod end power steering $12.34
Rear Suspension
951.331.021.01 Rear trailing arm, right $75.00
951.331.022.01 Rear trailing arm, left $75.00
951.332.235.01 Rear wheel shaft, 2x $37.50
999.053.020.01 Rear wheel bearing, 2x $22.80
951.331.067.00 Wheel Hub, rear, 2x $50.00
944.332.038.09 Drive shaft, right $50.00
944.332.038.10 Drive shaft, left $50.00
944.331.901.00 CV Joint, 4x $40.00
Custom Torsion bars, 13mm, solid (for use w/ coil over rear springs) $50.00
944.331.045.02 Rear-axle cross-tube $175.00
Body
477.807.109 Bumper, Front, 924S $112.50
477.807.155A Rubber molding, front impact pad, Left $21.00
477.807.156A Rubber molding, front impact pad /Right $17.50
477.807.301A Bumper, Rear $82.50
477.807.158 Rubber molding /R $27.50
477.807.157 Rubber molding /L $27.50
944.505.017.03 Impact absorber, bumper shock $17.50
937.512.555.00 Rear spoiler, 944, center section w/ L&R sides $187.50
477.827.555 Rear Spoiler, 924S, center section w/ L&R sides $150.00
944.219.888.09 0507 Driver side, 944 mirror assembly complete, alum frame, motor / glass $62.50
944.219.888.09 0505 Passenger side, 944 mirror assembly complete, alum frame, motor/ glass $62.50
Fender liner, front, left $40.00
Fender liner, front, right $40.00
Interior
944 641 015 02 Dashboard clock $22.50
477 959 530 Air-conditioning switch $15.13
944 641 117 02 Gage, Oil pressure $17.00
477 941 531 Switch, headlights $22.50
477 857 137 Cover light switch black; Bezel, headlight switch $3.08
477 959 623 Rear window heating switch $6.00
477 953 235 Emergency light switch; Switch, hazard $12.50
477 857 138 Cover switch rear window heating black /R; Bezel, defrost & hazard switch $3.08
477 862 185 Rear hatch release switch-satin black, w/ mouthing; Switch, rear hatch release $15.63
944.624.024.01 Rear hatch release motor $11.25
477.953.901 Turn signal switch, black $25.00
477.953.902 Wiper switch, black $25.00
944 617 150 Relay warning indicator oil level $62.33
944 641 030 01 Speedometer $72.50
944 641 310 02 Temp/fuel/pressure $37.50
477 857 123 1DB Glove box cover black /LL $20.00
477 857 283 AFP7 Instr.trim cover, black $12.50
477 953 515 B1DB Lining black, top $5.00
477 953 516 B1DB Lining black, bottom $5.00
321 905 851 Steering lock housing $22.50
477.957.807.B Drive shaft, speedometer cable $16.50
477 867 012 RKZ8 Door panel, passenger $25.00
Multiple Passenger seat, black, vinyl $112.50
Multiple Rear seat, lower, black, vinyl $56.25
Multiple Back seat, upper, black, vinyl $56.25
Race Parts
Eibach 6in x 2.25ID x 700lbs $30.80
Eibach 5in x 2.25iD x 950lbs $30.80
Fabcar Fabpin / ball joint for Fabcar a-arms $96.00
MSD Ingnition $88.00
Lindsey Racing Lindsey oil breather $75.00
Wheels
911.361.032.28 Hub cap black, for fuchs / cookie wheel, black $21.54
Engine
Electrical
Brakes
Suspension, Front
Rear Suspension
Body
Interior
Race Parts
Wheels
The seat is a black vinyl and is in great shape except a small tear on the back around shoulder level (rubbed a roll bar). If you shoot me an email (address above), I'm happy to send some pics.
