LeMons 944 Handling Problem (no back hatch)
Old 10-15-2014, 01:44 AM
ninjacoco
ninjacoco's Avatar
Default LeMons 944 Handling Problem (no back hatch)
My car is awesome to drive when it has at least half a tank of gas in it.
Not so much beneath then.
It doesn't have a glass hatch and is on pretty worn suspension, so the rear end likes to snap around when there isn't a lot of gas in the tank. Oof!
The suspension is--as Judge Phil called it--"comfy." And bouncy. It does well enough as long as you don't try to do a lot of quick autocross-style transitions (then it just flops all over, haha). Oh, and it's fine until it's low on gas. Grr.
So, a question for you running stripped-out 944s in crapcan series that tend to frown on keeping a glass hatch back there--help? Did you fix the handling somehow? Or is it just better to keep bringing people in as soon as the gas starts getting low? Bleugh.
The previous owner of my first 944 stuck a big 45-lb weight in the tire hole to even out the weight distribution when it ran out of gas, but that seems a tad silly.
Old 10-15-2014, 01:57 AM
Dave W.
Dave W.'s Avatar
I strongly recommend removing just the right rear shock. This won't fix the problem but it's an appropriate mod for a Lemons car.
Try to avoid lowering the rear end via the eccentric adjuster on the trailing arm to compensate for the lack of weight. Cars that handle too well might get penalized. Have fun!
Old 10-15-2014, 02:53 AM
ninjacoco
ninjacoco's Avatar
It's not cheatin' if it doesn't cost $$$, right? Right.
Its rump is pretty high. I'll have to look into this adjuster. It's an '84 car, if that helps any.
Old 10-15-2014, 03:34 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
Here's info on the spring plate eccentric adjustment, it might get you .5 - .75" lower. I run mine as low as it'll go.
https://rennlist.com/forums/924-931-...tric-bolt.html
Old 10-15-2014, 08:28 AM
harveyf
harveyf's Avatar
I weighed a hatch recently. 80 pounds! And that weight is up high. It's not a surprise that removing it changes the handling.
Old 10-15-2014, 12:13 PM
V2Rocket
Rainman
V2Rocket's Avatar
There was some error in your measurement my friend.
I weighed both of my 944 hatches and they are 52 lbs, complete with hinges and rubber spoiler.
Without that weight up there the back end is very skittish. Even driving with the sunroof open at highway speeds makes the tail wiggly because air can't get to the spoiler anymore.
If you can't run a glass hatch I'd build a rudimentary "window" out of maybe some aluminum spars and thick painter's plastic to at least aid aerodynamics somewhat, and full the spare tire well with weights or something. Find a place that sells turf lawns and buy a bag of the rubber pellets...
Old 10-15-2014, 01:23 PM
theamsoilguy
theamsoilguy's Avatar
Move the battery to the rear of the car.
Old 10-15-2014, 01:25 PM
laneskelton
laneskelton's Avatar
We ran a 944 in 5 LeMons races without a rear hatch and really didn't feel any of the negative effects that you are talking about. Our car was lowered in the rear as far down as possible and we has Bilstein dampers and turbo sway bars.
Old 10-16-2014, 08:53 AM
speedjw
speedjw's Avatar
You don't add weight to a racecar!
Put the car on some scales and corner balance it... Or at the very least level it. Lots of good reading on suspension setups over on the 944spec forums.
The hatch (in lexan) is legal in both lemons and chump, and it does help down long straights.
Old 10-16-2014, 05:36 PM
ninjacoco
ninjacoco's Avatar
Yeah--I think the ride height and floppiness is our biggest problem. It's tall. Floppy and tall.
Old 10-16-2014, 06:37 PM
odonnell
odonnell's Avatar
What about installing a ghetto rear spoiler? Like some sheet metal welded above the tail lights to supplement down force.
Old 10-17-2014, 03:03 AM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by ninjacoco
My car is awesome to drive when it has at least half a tank of gas in it. It doesn't have a glass hatch and is on pretty worn suspension, so the rear end likes to snap around when there isn't a lot of gas in the tank.
As suggested, I'd lower the rear end and run it 0.5"-1.0" lower than the front end [measured at suspension points or fender lips] to improve driving dynamics.
Also, if you have any rules flexibility with sway bars, I'd consider running a stiffer front bar or softer rear bar.
Old 10-17-2014, 08:23 AM
Voith
Voith's Avatar
Use two medium strength cargo belts one for each damper and secure them with strong zip ties. It will stiffen the torsion response and lower the car and you can adjust it in 5 minutes.
Express adjustable suspension.
Old 10-17-2014, 10:34 AM
V2Rocket
Rainman
V2Rocket's Avatar
thats actually not a terrible idea.
and they could work as limit straps too helping you stay flatter.
Quick Reply: LeMons 944 Handling Problem (no back hatch)
