1987 951 Transmission problems/needing one
Recently purchased a 1987 951. The car stopped shifting from 1st to 2nd gear today while driving to the office. All other gears shift fine: 1,3,4,5. Reverse can be a bit challenging to work. I'm assuming the syncro to 2nd is gone? Checked the obvious; fluid level for clutch, it's full. I tried shifting from 1 to 2 with the car not running and it will still not go into 2nd.
If my assumption is correct, does anyone know of a reputable company where I can purchase a rebuilt 951 trans with LSD and a warranty?
Appreciate all opinions and/or insight. Thanks
Basic Sponsor
2nd gear synchro is usually the first one to go, but I haven't seen it happen a lot on 951s. How many miles are on your car?
Where are you located?
You might try shifting from other gears into 2nd with the car off.
951 trans, 2nd gear inop.
I have not checked the linkage. What would be the relationship between shifting into 2nd unsuccessfully but being able to shift into all others?
Also, the car has apporx. 155,000 miles. I assume its the orinigal trans?
There's an 87 lsd turbo trans on Houston craigslist. Woukd you sell your old trans? I might be interested. I can pick up too. Hell, I'll remove the old one and install the new one for a discount or something. PM me.
The one I'm talking about is 5 speed....It's a 9U, the same trans in using in my car.
http://houston.craigslist.org/pts/4626715980.html
