Bad Gas in the tank
Agree with Van. It's a gravity feed up to the pump inlet. Also, if there is any chance of particulate matter in your bad gas, you don't want to run it through the pump. It will lock the pump up solid. Ask me how I know
While you are in there take a large wrench, remove the large nut on the outlet of the tank, and remove the mesh filter element. Inspect for tears and gently clean off any residue. New ones are not all that expensive either. Pour a little fresh gas down the filler and let it run out of the bottom of the tank while the filter element is out to flush out any sludge, etc. And you will probably want to replace your fuel filter downstream of the pump.
Yes, Harvey speaks wisely!
If the tank has more than 5 gallons, I use these clamps to pinch off the line while I get another gas can ready. http://www.harborfreight.com/4-piece...set-65116.html
I use Van's method also. May want to also consider changing out the sock on the inside of the tank, its inexpensive and no better time than to do it now.
