951 Fuel pressure gauge reading question
I just installed the 951MAX chips from Lindsey Racing along with an adjustable fuel pressure regulator. I connected an Arnworx fuel pressure gauge to the fuel rail. with the car idling the pressure reading centered around 36 PSI. I adjusted so that the reading was centered around 44 PSI (3 Bar) per the chip requirements. At Idle, the needle rapidly bounced +/- 5 PSI around the center point. When I rev'd the engine to 2000 RPM, the pressure reading settled out some to about +/- 2 PSI around the center point. Should the reading bounce that much or is this indicative of another problem? The car will absolutely haul *** and runs great. thx
