Clutch judder
Old 08-09-2014, 09:26 PM
Last Lemming
Last Lemming's Avatar
Default Clutch judder
Why is it I get clutch judder taking off from first gear when the car is cold and warming up and fine once fully warmed up
Old 08-09-2014, 11:16 PM
Volhv_944
Volhv_944's Avatar
Smells like a glazed, warped, flywheel. Once the clutch warms up, maybe it grips better.
Old 08-10-2014, 01:45 AM
drive135mph
drive135mph's Avatar
mine does it if it gets too hot for example when driving through NYC in the middle of the summer, I find that mine improves with normal use, but yes Volhv is probably correct
Old 08-10-2014, 02:48 AM
Dougs951S
Dougs951S's Avatar
+1, glazed and/or warped clutch/flywheel.
Old 08-10-2014, 12:00 PM
arthropraxis
arthropraxis's Avatar
Could be some air in the lines. My car does this sometimes, after a bleed it goes away.
Old 08-12-2014, 02:07 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
My original rubber center clutch shudders a lot when hot. Example, when I drive 30mins to my local car show in the summer, when I'm finally in the parking lot and getting on/off the clutch over and over as I make my way through crowds of people, it usually shudders pretty bad. Yours is the opposite though
Old 08-15-2014, 03:53 PM
GARG
GARG's Avatar
Believe it or not on a 87 944S changing to a new chip made all the difference in the world.
Old 08-15-2014, 04:01 PM
Biscuits704
Biscuits704's Avatar
Like Butters I get this, hot and cold, but mostly hot.
There's still life left in my clutch, apparently.
According to my research (lot of threads out there on different forums worldwide), it's likely related to the rubber center in the clutch.
I'm going to live with it for now (clutch operation is now an exciting challenge of skill and patience to see how smooth I can disengage) until I can't take it anymore and throw in the towel with regards to a new one.
Old 10-31-2014, 11:11 AM
Last Lemming
I don't think the 86 had a rubber center on the clutch but I could be wrong.
Let's assume for the moment that it's not a hot spot on the plate. What else could it be? I've bled the hydraulic slave cylinder and its up to par. Could it be a tranny mount or clutch pedal adjustment (though the pedal doesn't seem out of shape.
I spoke with a Porsche mechanic about my situation briefly and he suggested a hot spot on the plate, but couldn't explain what the symptoms went away after the car warmed up.
I really don't want to go through 20+ hours of work to find out the plate or clutch is not the issue.
Old 10-31-2014, 11:18 AM
Darryl H
Darryl H's Avatar
My '86 Lux had a rubber center that was destroyed when we took it out.
Old 10-31-2014, 04:16 PM
944Ross
944Ross's Avatar
Does your rear main seal leak? If you are getting any oil into the clutch, it will take a few miles to sling out, and it makes the disc sticky.
Old 10-31-2014, 09:12 PM
Last Lemming
The rear main seal does not leak and when I remove the starter I don't see any evidence of debris. Though I'm not sure I would be able to see any regardless
Old 11-01-2014, 11:10 AM
lart951
Basic Sponsor
lart951's Avatar
I believe he has a 951, turbos did not have a rubber center like the 944na.
Old 11-01-2014, 01:36 PM
bumflick
bumflick's Avatar
I have a similar, but different issue - in high gear, while decelerating, I start to get serious bucking around 2000 rpm. Down shifting a gear or two normally takes care of it, but it seems odd that the car should be so unhappy at this rpm.
86 951, 3 inch cat delete. 3 bar fuel pressure regulator.
Is this normal? Clutch seem normal when moving from a standing start or in normal shifting. Only other issue is bringing first to second when trying to shift quickly, but that seems to be synchros.
Old 11-02-2014, 01:13 AM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by bumflick
I start to get serious bucking around 2000 rpm...86 951, 3 inch cat delete, 3 bar fuel pressure regulator.
Why are you running a 3bar FPR?
Quick Reply: Clutch judder
