Top Dead Center Question
Before I pulled the head on my 86, I wan unable to put the engine at top dead center using the aligning marks. The valves were jammed up on the pistons (how I bought the car) and would not allow the engine to fully rotate. Anyways, I am going to clean the block up today, remove the timing and balance belts and install the head and I wanted to make sure the engine was at top dead center the way it sits before I install the flywheel lock. I don't believe it can be 180 degrees off at this point, but that's what I'm making this post. This is the first head job that I've done on a 944. Here are some pics:
Awesome. Where should I be looking at on the flywheel? Are the marks going to be visible once the starter is removed or visible from the inspection cover hole?
I point out what you're looking for in this video. There is "OT" and a line on the flywheel, and a metal "blade" inside the bell housing inspection hole.
For the future, leave the exhaust header connected to the head, it's much easier to take out that way (and fewer bolts to undo!)
Excellent link, thank you!
Awesome video Van, thank you!
Van's video give a very good overview and points out the view port for the flywheel TDC mark. Before I take my belts off again, I'm going to paint the flywheel TDC mark like Van has done. When I first bought my 924S, two valves were bent and the belts were all torn up and two pulleys were broken. The TDC mark was somewhat difficult to find because of corrosion and doing it by myself was a long process. Have a bright flashlight and get a friend to help turn the crankshaft while you look in the view port.
Also, it looks like your balance shaft belt is still mounted to the crankshaft. Look at Van's video and use the balance shaft pulley markers to get close to TDC.
Yea, I left the balance belt on. I bought the car knowing it had bent valves. Guy I got it from said he had the belts and water pump done 15k miles ago and the engine stalled in traffic and would not start. The belts and tensioners look fine but all eight valves were bent. Not sure what happened really. I'm thinking that whoever installed the belts did the job incorrectly and bent the valves on startup.
Van, on a side note, my valves were not sticking out like that. They were cocked in the head and When light was shined through the intake and exhaust ports, I could see light through them at the sealing surface. I honestly don't know what caused them to bend.
