Very Low Oil Pressure on Start Up
With little to no warning when cold, oil light on and very little oil pressure (<1) for 30-45 seconds. No horrible noise, but sounds rough.
First instance I let it go, got full bar and once warmed up seemed fine. Started up again 1 hour later, (oil still warm) a little rough but 2.5 oil pressure.
Next cold start, oil light on, no pressure, shut off.
OPR, Pick up tube, bearings? Did not check crank bolt yet.
85, 180K
85, 180K
When was your last oil change and what oil did you use?
I'd start with pulling apart the oil filter to see what sort of particulate matter you have in there before proceeding any further.
p.s. Od is going to appear in this thread soon to tell you to swap to a LS. Don't be surprised.
20/50, less than 3K ago.
Filter changed no metal to be seen.
Decided to check oil cooler myself, everything looks normal and reinstalled, no change. Thinking it may be a cracked pick up tube, any way to test w/o dropping pan?
OPRV checked as well.
Sludge in oil pan?
85, 180K
85, 180K
Good Luck,
Mike
