Longer wheel studs vs spacers
How long/deep are the spacers you're using?
From a conversation with an old school race engineer from a few years ago, I am of the understanding that anything up to 10mm is fine as a hub-centric spacer.
I don't have any qualifications in the area, nor have I studied the information I was given.
However - I was advised by a source that I trust to avoid using spacers longer than about 10mm when possible.
Professional Hoon
I will be using hub-centric spacers, either with longer wheel studs or bolt on spacers (what the 944 has)
I'm just tossing up between the 2 options.
We went with longer studs up front on my S2 to get the 996 wheels mounted with a 7mm spacer. Its the way to do it, i trust it way more than a bolt on spacer deal. Steel lugnuts are also good idea.
Run a high quality hub-centric spacer and the proper length lug bolts and you will be fine. I'm not a fan of anything above 10mm as it adds a much increased element of weakness to the hub, a wide spacer and longer studs is never going to be as strong as a correct offset wheel on stock studs, but then again I've known people who run with wide spacers without issue.
If the spacing required is more than 10mm, like 25mm, use a bolt-on spacer with its own studs. If the spacing required is low, like 5mm, use a slide-on spacer with longer studs, because there's no bolt-on spacer that thin.
Pros of bolt-on spacers: waaay easier, change/remove at will.
Cons: heavier, minimum thickness.
Keep in mind, if you use very long studs, when you try to run without spacers they will poke out .
Agree with most of what's been said here. However re: "Can you get studs cheaper?"
Please don't go cheap here. You get what you pay for. And if you are going with a wide spacer you really don't want to combine that with "cheap".
And if you are going to ever track the car... keep the spacer width under 20mm. Preferably under 10mm on the "heavy" end.
The brand name is O.E.M. but that doesn't mean it's the original equipment manufacturer. I'd call Sunset and ask for a price on the studs.
