FS- Lloyds mats, Vitesse AFM chip and other parts
Old 06-30-2014, 12:39 AM
azbanks
Freedom Enthusiast
azbanks's Avatar
Default FS- Vitesse Stage 2 turbo and other parts
Vitesse Stage 2 turbo. Early model. Less than 2000 miles since complete rebuild by Arizona Turbo and Tractor supply.
$1000 OBO.
Autothority 26/6 AFM chip $60.
<Original post>
Complete set of Lloyds mats. They are all black, just different amounts of fading.
$150 shipped in the US - SOLD
Old 06-30-2014, 03:07 PM
bumflick
bumflick's Avatar
What is the big one? Is that for the trunk?
Old 06-30-2014, 03:15 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
Yes, it is for the trunk. This is the full set, front seats, rear seats and trunk.
Old 07-01-2014, 11:19 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
delete
Old 07-01-2014, 11:20 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
Vitesse and Autothority chips.
Vitesse = $200 - SOLD
Autothority = $60 shipped in US
Old 07-02-2014, 02:16 AM
mel_t_vin
mel_t_vin's Avatar
Does Lloyds even make/sell this full set anymore?
Am considering your Vitesse chip. Would you happen to know for what configuration that chip is designed? What additional elements [FPR, injectors, MBC] would be required? Does it come paired with a KLR chip, as well?
Have you run your car with both the Autothority and Vitesse chips? If so, how would you compare/contrast their sensitivity/responsiveness/operation across the driving spectrum?
Old 07-02-2014, 03:58 AM
azbanks
Freedom Enthusiast
azbanks's Avatar
I do not know if Lloyds still makes this set. I haven't seen anyone carry the rear piece in a long time.
The Vitesse chip is for the factory AFM with the 26/6 turbo. It is for a basically stock system and uses the factory KLR chip. The only other item you will need is a 3 bar fuel pressure regulator.
I bought my car with the Autothority chip. A friend recommended upgrading to the Vitesse chip. The Vitesse beats the Autorthority chip to death in all areas. More responsive and better drivability everywhere. Part throttle, full throttle, it is just a better chip.
Old 07-02-2014, 01:40 PM
mhr
mhr's Avatar
are the mats out of your cab? Does the trunk piece fit in the cab trunk well?
Old 07-02-2014, 01:48 PM
V2Rocket
Rainman
V2Rocket's Avatar
that rear mat is a good snag.
Old 07-02-2014, 02:50 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
They are out of the 86 turbo that got totaled.
I do not know if the rear would fit in the cab. It looks like it would fit. I never tried it and now I would have to pull the two amps, the sub box, and a bunch of wires to test fit it.
In any event, the mats are SOLD!
Old 07-02-2014, 11:59 PM
mel_t_vin
mel_t_vin's Avatar
When you ran the APE chips, did you run stage 1 [0.8 bar] or 2 [1.0 bar]?
If this chip is designed to run with the factory KLR chip, I wonder why a 3 bar FPR is stipulated? As you know, the factory KLR is limited to 0.8 bar. Any idea what range of boost is this chip designed for? Is it limited to run at 0.8 bar? Is that how you ran it when you changed over from the APE set up?
Do you have any paperwork with this chip?
Old 07-03-2014, 02:56 AM
azbanks
Freedom Enthusiast
azbanks's Avatar
I do not know what stage the APE chip was running. It was already installed when I bought the car.
I did use a manual boost controller with the Vitesse chip. You don't have to but it is an option. I was running 15 lbs of boost. You could go to probably 16 lbs without worrying about anything. If you want to go higher than that, I would recommend a wideband O2 sensor to keep track of your A/F ratios.
I do not have any paperwork with either chip.
Old 07-03-2014, 09:06 AM
black944 turbo
black944 turbo's Avatar
I am running the same vitesse chip and there is no KLR chip. John designed it to run a 3 bar and an MBC with the stock KLR. You may have to adjust your FQS to your setup, if I remember correctly.
Old 07-04-2014, 01:40 AM
mel_t_vin
mel_t_vin's Avatar
Out of curiosity, what boost have you been running? Does this chip automatically adjust fueling to whatever boost is run [0.4/0.8/1.2 bar]?
My understanding is that the factory KLR/CV [built-in] overboost trips around 1.1 bar. That said, in order to run higher than factory boost, I thought most folks that run a DME chip without a modified KLR chip choose to bypass the CV [to avoid overboost] and run an EBC/MBC instead.
So, with this chip and MBC, you have been running with the stock KLR/chip but a bypassed CV?
Old 07-04-2014, 01:48 AM
bumflick
bumflick's Avatar
This was a steal on the mats. For those that were asking, automobile atlanta appears to carry the Lloyds mats. Autoatlanta.com
Is the Vitesse chip still available?
Quick Reply: FS- Lloyds mats, Vitesse AFM chip and other parts
