Turn signal / marker bulb out?
Old 04-15-2014, 11:10 AM
ChrisRL
ChrisRL's Avatar
Default Turn signal / marker bulb out?
Hi
My driver's side front marker light is out, but the turn signal works.
By front marker I mean the orange light that's also the turn signal, but goes on when the car's running and blinks when turning.
My passenger side is working - it's always on, but blinks when turning.
So I opened the light unit up and found only the one bulb fixture.
So is it the bulb gone out? Or do I have to trace wiring or some kind of logic/relay error?
Thanks!
Old 04-15-2014, 12:07 PM
konakat
konakat's Avatar
It may be a two-filament bulb with only one filament burnt out. Or it could be an electrical contact somewhere. I would check the bulb first, then try cleaning off the contacts on the back of the light housing.
Old 04-15-2014, 12:31 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
+1
The bulb is a 2-filament bulb, one for the running light, one for the signal. I bet one of the filaments is burned up. Just swap bulbs and find out
Old 04-15-2014, 02:46 PM
ChrisRL
ChrisRL's Avatar
Gotcha.
This bulb replaces from the front? Or the rear? Mine is, of course, well stuck in there...
Old 04-15-2014, 03:13 PM
turboS_swede
turboS_swede's Avatar
Maybe check the owner's manual or the Hayne's manual?
Old 04-15-2014, 03:56 PM
Butters944
Today I got
My Custom Title
Butters944's Avatar
If your question wasn't for an NA car my answer may not be correct
Quick Reply: Turn signal / marker bulb out?
