Integrated radar detector project
This one is still in the early stages, but I think it could turn out really well.
My plan is to gut the center speaker area on the early dash and install a Valentine One radar detector. I want to dremel a cutout on the speaker grill so it's a clean and integrated look:
(very rough mockup)
The wiring would tap the cigarette lighter. Since this always receives current, I would mount a switch somewhere. Ideally, I could modify a sunroof switch from a parts car and have it on the center console, nice and inconspicuous.
I'm not sure about the cigarette lighter wiring (i.e. which wire is gnd and whatnot) but here's the rough diagram:
From the factory, the V1 plugs into the cigarette lighter so I know it's be straightforward and I won't need any inline resistors or anything.
To those who have added gauges and whatnot to their speaker housing, what potential caveats might I face? The V1 is pretty big, but I'm willing to cut if I need to (I'm recovering a donor dash eventually, and I plan to do this when I procure it).
Thanks, as always for insight!
(very rough mockup)
You setup won't work, if you put the V1 in the speaker grill, it won't be able to pickup laser or radar cuz you'll be blocking the lens.
I actually mounted my V1 up high near the rear view mirror, and ran the wiring down the headliner onto the passenger side and pickup key on power there. Higher up gives you better range, and you can barley notice it from behind which is good... If you'd like I can post pics
I was thinking about alternatively mounting it somewhere like under the visor, and installing a satellite display in the speaker grill, along with a oil temp gauge perhaps.
This thread is a good idea of what I'm aiming for: link
You could mount the concealed display in there, but you sit so close to the windshield in a 944, I don't think you would gain anything. https://store.valentine1.com/store/closeup_20110.asp
Also, does the lighter have constant power, I can't remember? You don't want to wire it to constant power and switch it because you will forget to turn it off and you will drain your battery. The V1 come with the hardware kit, and just connect it to the radios switched power.
Yep cigarette lighter is constant power. I think wiring it to the ignition switch would be another viable alternative.
I do like the idea of radio power, it will receive current whenever the key is in the switch.
I suppose i could go with fast924s' solution, radar detectors are still legal in TX
Maybe put the radar detector in the sun visor?
That way, you could flip it the other way to conceal it when parked, etc.
Somewhere around here I have a spare visor, which I replaced because its seam was split. Could do surgery through the split seam, remove some internal foam to make a place for the radar detector, so it would not be lumpy when finished. Route the RD wire through the visor mount. On my BMW is a visor with a sliding mirror cover, and a little light comes on when the mirror cover is slid open. Ideal switch for radar detector power. Adapt to Porsche?
I have the V1 just right of the mirror, hard-wired in and the remote display in front of the instrument cluster. It is 95 % out of the way, the corner of the box is the 50 mph mark; it can be slid outboard a smidge more.
It is easier to use the mute button here, too. Been awhile but I think I just made a wire clip to mount it, goes up and around the back of the cluster 'tunnel' just in front of the cluster bezel face and the V1 wiring sneaks in this way too. All fairly simple as these things go.
Mount it as high as you can without having the lens in front of any extra tint. Tinting cuts the range. Make sure it has a clean shot out of the back hatchglass too for the rear antenna cluster.
THIS is what I'm going for - a remote sensor that I can run through the firewall, and have the actual unit in a discrete location. I'd like the interior to be a clean as a whistle... and more importantly... I live in Waco and crap gets stolen out of cars all the time
I've read great things about the Valentine One, and not-so-great things about Cobras.
The V1 also supports a satellite display: https://store.valentine1.com/store/closeup_20110.asp
This would let me mount the actual V1 unit say, in a cannibalized sun visor for good reception, and then observe the readout from wherever I stick the satellite display. The current plan is to make use of the speaker grill that's awkwardly hanging out in the middle of the dash.
I couldn't find any remote sensors for the V1 that I was sure would work, so this seems like the best solution to solve for both reception as well as discretion.
Both Valentine and Passport sell mounts that attach to the rear view mirror. This puts the unit in the preferred high location for the antennas and gives the install an OEM type look. It can be completed with a remote display and hardwiring too.
