The most complete Poly Bushing Kits available for 924, 944 & 968
Former Vendor
Back in 2008, we did a bunch of analysis to try to identify complete suspension bushing upgrade options. At that time, there was no single vendor that had a complete package of polyurethane bushings that covered the entire range of 924, 924S, 944, and 968.
Last year, Power Flex rounded out their offerings and now provide almost all of the necessary model-specific bushings to re-do the entire suspension in Poly. The only pieces they do not offer at this time are the upper strut mount bushing, the upper torsion carrier mount, and the torsion carrier wing mount. Everything else is now available for virtually every iteration and combination conceivable, including:
The complete range of Power Flex bushings are now available on our Suspension Upgrades page, along with all of the OEM replacement bushings, including some of the additional hardware components (like upper strut mounts, rear sway drop links and eccentric adjusters).
Also, we have made some significant upgrades to our site recently, now offering the ability to create user-configurable kits, which should streamline the selection and ordering process.
- Front a-arm bushings (steel & alu a-arms)
- Castor blocks (steel & alu a-arms)
- Sway bar main bushings
- Sway bar end bushings
- Sway bar drop link bushings (all three versions now supported)
- Rear sway bar bushings
- Main torsion carrier to chassis bushings
- Trailing arm to torsion carrier bushings
- Spring plate to torsion carrier bushings
Former Vendor
Ahhh, very interesting, thanks much for the heads up, I'll see if I can borrow one to do some testing on. I tested on my Galaxy tablet, so it must be something with the Javascript code and how the iPad browser interprets it.
In the meantime, you can always email or PM me with your needs and I can put some package pricing together for you
Former Vendor
You have to force it to reload the page...it's caching the previous version of the page. I switched places with the $ field and the add to cart button, so that screenshot is still showing the previous version of the page.
Yep worked well.....going to delete my previous posts now to clean up your thread.
I do need bushings for a 1986 951 non m030. What do I need to measure to figure out what I need?
Former Vendor
Go to this link:
http://garage.ideola.com/prod-Suspen...#PolyLateFront
You should need the "ROUND" style castor block bushings, but double check, as PET is not entirely clear which castor blocks came on which models, and it's possible a previous owner put a different style on. You will need to press the old rubber bushings out of the steel brackets.
Measure the O.D. of your front and rear sway bar, then select the appropriate sized sway bar bushing.
Hope that helps!
Hope that helps!
Former Vendor
So the new poly bushings can be inserted without using any tools
Former Vendor
And for those desiring more stiffness (yeah, I know, that's what she said), we've just added a number of Competition Suspension Components from Tarett Engineering.
Former Vendor
