No Start 89 S2 (No spark or fuel) at my wit's end
I have a 1987 944 NA chassis with a 1989 S2 engine swapped in. The engine bay and DME harnesses were both swapped over as well. I have jumpered the DME relay, bypassed the factory alarm and swapped the DME and DME relay into a running S2 to verify each worked. At this point, the car will not start. I have already tried searching the forum but it seems that no one has had a similar problem with an S2.
I have the following symptoms:
- Tach bounce while cranking
- Fuel pump does not come on when ignition is on accessory or while cranking
- No power across the coil
- Fuse 34 is good/not blown
I have verified that pin 86 on the DME relay is getting 12V+ power when cranking. I have installed a brand new fuel pump, brand new ignition control module and a new coil. I'm truly at my wits end as to what is left to check. I know it's likely that there is a wiring problem somewhere but I have no idea where to check from here. Help!
I'm obviously a rookie, but I'm up for a game of 'sounding board.' Any chance of swapping the computers? Definitely no spark AND no fuel?
When you jump across the DME relay, does the fuel pump run then?
Edit: Oops, I see that you've tried the DME from the running car too, not just the known good relay.
Last edited by pontifex4; 11-14-2012 at 06:55 PM. Reason: Bad reading comprehension
I can't find anything definitive in the FSM, does anyone know if the factory alarm kills the fuel and spark? It seems that is the most likely suspect right now.
I was messing with my car stereo..and it had the same symptoms. I must have triggered something...I think I unplugged the battery/reattached and it started...I cant remember. It was weird as it was the only time it ever did it.
The other candidate is the airbag module, though as I understand it, that would only disable fuel.
Was really hoping someone had experienced this before but it seems as though I've brought a new problem to the Rennlist brain trust.
Have you compared the schematics?
Did you make appropriate changes to the 14 pin connector by the fuse box and passenger floor?
Did you add the Fuel Injector Ballast Resistor circuit with the harness?
Did you add the Ignitor circuit part of the harness?
